Help Needed: Rear Alignment Shim Info/Insight
Discussion in 'Gen 3 Prius Technical Discussion' started by MrPete, Feb 8, 2024.
  1. MrPete
    MrPete Active Member
    507
    194
    Colorado, USA
    In another thread, @The Critic used NAPA-numbered versions of (Spicer? NO -- MOOG!) alignment shims, heavier duty than the typical SPC shims for fixing rear alignment.
    I'm needing to go down the same path, but running into roadblocks.
    I found the NAPA P/N's:
    * 2643055 "up to +/- 1/4 degree Camber & up to +/- 1/4 Degree Toe"
    * 2643056 up to 1/2 degree
    * 2643057 up to 3/4 degree
    * 2643058 up to 1 degree
    And now I know these are MOOG shims, P/N K6660-1 K6660-2 ...3 and ...4 . These are available from MANY sources. Home Depot can source for under US$7 with free shipping for example.
    I can't find complete instructions online. Here at PriusChat I've found a portion of one or two instruction sheets / charts. But many people have commented that the charts often make no sense, and are not even consistent from one sample to the next. :( (See links below)
    My main questions:
    • Has anyone succeeded in using these Moog shims?
    • Does anyone have a copy of the instructions / templates / calculation charts that actually works for Prius? (They "ought" to be compatible with Gen2 and Gen3.)
    Links
    Discussion incl some charts: Rear wheel alignment, need help with the shims | PriusChat
    PDF of chart portions: https://attachments.priuschat.com/attachment-files/2019/08/172021_alignment_help.pdf
    • The charts in these links are partly confusing b/c they refer to shim types 1 to 6, but only 1 to 4 are sold ?!!
    • In addition, the above discussion has people who tried to use the templates and found they don't match at all. Bleah.
    And finally, specific to my situation:
    • My rear toe is currently way out on the right but close to right on the left.
    • Am I correct in thinking I can adjust both a bit to obtain the needed total toe, and THAT is what actually matters for toe? (That's what I'm understanding as I read.)
    THANKS HEAPS!
  2. MrPete
    507
    194
    Colorado, USA
    Problem(s) solved
    • Picked up a K6660-2 (1/2 degree supposedly) shim at Advanced Auto. $8 incl tax. Then I returned it because it's actually too small (see below.) Picked up two -4 shims at NAPA. Paid a little extra to get it today and to support a locally stocking business. :)
    • Scanned most of the charts.
    • NONE of the key info is online.... until now :)
    • Spoke with a tech expert at MOOG and got my remaining questions answered!
    Either here now or through a future upload/link, I will provide the charts and templates needed for Prius rear alignment shims.
    New Insights
    1. The Make + Model table is completely bogus. Throw it away. (MOOG no longer has it internally either!)
    2. Trust the (color) Template Sheets. Prius Gen 1 and 2 use Template "P". Prius Gen 3 uses Template "Q". (MOOG internally has an updated Template Sheet showing Q is for Prius 2010-2015, ie all of Gen 3.)
    3. On the Toe & Camber chart, ignore the two "outer" curves that are for Shim #5 and Shim #6 -- those products do not exist.
    4. Ignore ad copy / descriptions that say each shim handles up to N° toe and N° camber. It's actually one or the other... or a fractional combination of both in an asymmetrical curve. See below.
    The full Toe & Camber chart shows that each shim version works for a sliding scale of Toe & Camber, and it isn't as simple as a certain range.
    • #1: 1/4° camber shift at zero toe... to 0 camber at 1/4° toe
    • #2: 1/2° camber at 0... to 0 camber at 1/2 toe
    • #3: 3/4° camber @ 0 to 0 at 0.74° toe
    • #4 1° camber @ 0 to 0 at 0.99° toe
    BUT it is a curve and not symmetrical. For example
    • #2 you can do +- 1/4° toe, and you'll get either +1/4 or -3/8 camber
    • #3 you can do +- 1/2° toe, and get +3/8 or - 1/2 camber
    • #4 +-0.74 toe gives +1/2 and -5/8 camber
    #2 MrPete, Feb 9, 2024
  3. MrPete
    507
    194
    Colorado, USA
    MOOG (and NAPA) Rear Alignment Shim documentation: instructions, templates, toe & camber chart. Shared with permission from MOOG Tech Support.
    (IGNORE Page 2, the Make/Model/Template table!)
    (IGNORE #5 and #6 toe and chamber chart entries on p5-6!)
  4. Mendel Leisk
    42,293
    Pretty deep stuff. This will correct for camber? They go behind wheel bearings, correct?
    Just rough checking with a carpenter's square pushed up against our rear wheels, seems like one side is well out of spec for camber (too much), and markedly different than the other side as well. Regardless, no apparent problems with tire wear or whatever.
    FWIW, our rear camber readings, from an alignment place:
    Left: 1.7 degrees
    Right: 1.2 degrees
    Maybe all is good. Spec for camber may be -1.48* degrees, plus or minus 0.5 degrees.
    * For 15" wheels, and -1.47 degrees for the 17". (hardly worth mentioning)
    I say "maybe" because this Repair Manual excerpt is maddeningly bereft of indications that they're discussing front vs rear.
    #4 Mendel Leisk, Feb 9, 2024
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Hmm, I wonder if they'll work on my 2016 Toyota Corolla S plus rear driver's side wheel/hub. The camber is off.
    The Prius hubs are similar.
    SM-G781V ?
  6. MrPete
    507
    194
    Colorado, USA
    Here's part one of two of a VERY brief example showing the shim and installment:
    Yes, yours is pretty good. Mine right now is
    Left -1.0° Camber, -0.13° Toe
    Right -0.6° Camber, -0.99° Toe (hit a curb last winter; this is the last remaining aspect needing a fix :( )
    Remembering that Josh our PriusChat resident alignment expert (and others) emphasize that for Toe it's Total Toe that matters.
    Total Toe spec is +0.29° +- 0.30° but right now mine is -1.12°. :(
    Interestingly, similar to the video, my (Firestone lifetime) alignment place printed out a couple of recommended templates from their system. Their recommendation uses the NAPA SPC EZ shims which I don't want to use (too thin/squishable -- see elsewhere here.) Their suggested shim adjustments are:
    Left Camber -0.5°, Toe +0.30°
    Right Camber -0.8°, Toe +1.15°
    Producing a final result of
    Left Camber -1.5°, Toe +0.17°
    Right Camber -1.4°, Toe +0.14°
    Total Toe +0.31°
    Nice... but the MOOG shims can't do that big adjustment on the right side. However, I can get there.
    Here's my calculations... and more observations about the difference between EZ Shim and MOOG:
    EZ Shim (and templates) have 40 sections in the 360° circle, ie 9° per section.
    MOOG (and templates) have 60 sections in the circle, ie 6° per section. Finer resolution means better accuracy in theory....
    EZ Shim have two elements in the circle that slide past each other. This means they are VERY thin.
    MOOG is a single solid piece. Thicker, obviously more stable.
    What I can do with two -4 shims:
    Left Camber -0.5°, Toe +0.83° (Left/In marker at 304°)
    Right Camber -.88°, Toe +0.57° (Right/In marker at 35°)
    Result
    Left Camber -1.5°, Toe +0.70°
    Right Camber -1.48°, Toe -0.42°
    Total Toe +0.28° (presumably the imbalance will self even-out.)
    I've picked up a loaner large torque wrench from AutoZone for this little project... I think I'll start a separate thread to describe the adventure of installing the shims.
    #6 MrPete, Feb 10, 2024
  7. MrPete
    507
    194
    Colorado, USA
    Found a nice YT video showing replacing the hub -- the 4 hub bolts are what hold the shim in place...
    #7 MrPete, Feb 10, 2024
  8. MrPete
    507
    194
    Colorado, USA
    @xliderider I don't know. You could call MOOG tech support and ask! They have more info. (1-800-325-8886 and punch numbers to get to MOOG. Lots of brands there.)
    Here is the complete compatibility list from the included templates:
    Buick (all) - U
    Cadillac (all) - U
    Chrysler 200 - T
    Honda Fit (07-13) - U
    Hyundai Accent (06-11) - O
    Kia Forte, Soul - S; Rio - O
    Nissan Cube, Versa - O
    Oldsmobile (all) - U
    Pontiac VIbe - S
    Scion xA, xB - O; iQ - P; tC, xD - Q
    Toyota Corolla (03-08) - S, (09-13) - U;
    Toyota Echo - O; Matrix - S;
    Toyota Prius Gen1,2 (01-09) - P, Gen3 (10-15) - Q;
    Toyota Yaris - P
    Volkswagen Passat (98-10) - T
    #8 MrPete, Feb 10, 2024
  9. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    Why do they always want to remove the hub the hard way????
    You need to rotate it left and right and then put it so it blocks the whole
    for the bolt, then screw the bolt from the back to put tention on it and
    smack it with a hammer, then tighten the bolt. Spray rust penatrent
    between the hub and the bracket. It's so easy this way.
    He should have replaced the guide pins....
    And should have removed the rubber boot and properly cleaned the inside.
    He should have put antiseize past on the hub and matting surface and on the
    disc. Then the next time is will be siimple to remove...
    He should have used the proper tool to turn in the disc puck....
    He could have easily torn the dust boot.
    And he needs to learn on to properly use the torque wrench. You never bounce it!
    There videos are good at showing you "a" way to do it, a good guide.
    MrPete likes this.
  10. MrPete
    507
    194
    Colorado, USA
    Thanks! I read about something like this... seems it ought to be doable without so much effort.
    I'll try to feel my way through your description when I go after it tomorrow...
  11. MrPete
    507
    194
    Colorado, USA
    IMPORTANT UPDATE for future readers:
    1. The "real" product source is Northstar Products. Northstar Manufacturing :: Our History
    2. A link to full product documentation. This link has the current list of supported vehicles (click on the expander to get them all.) Northstar Manufacturing ::
    3. Top right of the page in #2 has links to the current PDF template file, and the PDF camber/toe lookup table PDF.
      1. Camber / Toe lookup as of today: https://www.northstarmfg.com/userfiles/files/95-035%20Standard%20Shim%20Chart(19899).pdf
      2. Template PDF today: https://www.northstarmfg.com/userfiles/files/95-288-0613%20Black(19917).pdf
    4. The Gen 3 Prius template is wrong, period. NONE of the templates are correct.
    Tech support explained that most shop techs don't bother with a template. Instead, do this:
    1. Use the toe/camber chart to get the angle you need to dial in. Place the shim on ANY template with the zero notch up, then mark the angle you need. (To correct for the axle-drop angle, you can SUBTRACT 4 for left side, and ADD 4 for right side. See below.)
    2. Do the disassembly
    3. Hold the shim up, with the mark straight up. Mark location of the four bolts, and knock out those sections.
    4. Assemble.
    NOTE: Axle-drop angle is real. The impact on adjusted camber/toe is small (about 0,1 degree max). For perfect accuracy, use a separate jack to raise the axle while installing/placing the shim. Or just factor it into the angle :)
  12. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    If possible, I like to get a hold of the OEM alignment points so I understand why an alignment of out of spec.
    Not to make a rear alignment issue more complex that it already is, but this thread got me thinking about the thrust angle. And not being an alignment specialist with a laser alignment ramp, I needed to lookup some stuff about how the different angles and directions played with one another in the 4 wheel alignment scenarios, than try an extrapolate / imagine what is going on when only doing the rear in place.
    HOW TO READ AND UNDERSTAND A WHEEL ALIGNMENT REPORT - Mevotech
    a baseline alignment report can help gauge results of how close in some alignment aspects and how far in other aspects the shim install has.
  13. ASRDogman
    8,052
    4,083
    If the real alignment is off, likely something is worn out, or bent.
    The same for the front. There is no real adjustment except for the toe adjustment.
    Any longer, only the higher end vehicles have caster/camber adjustment.
    And independent suspension for the rear usually has it.
  14. Mendel Leisk
    42,293
    Yeah 3rd Gen being a solid rear axle, a single welded component, shims under the bearing are the only way to change anything. 4th Gen is independent rear suspension.
  15. vvillovv
    4,336
    1,518
    NY
    An alignment video explanation by AMD about alignment issues that I timestamped in the middle of hoping it sheds some light on something for anyone.
    youtu.be/jtptaIYgIHQ?t=490
