Help Needed - Strange Behavior as of today
Discussion in 'Gen 3 Prius Technical Discussion' started by 15SuperPrius, Oct 27, 2019.
  1. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Hi folks,
    As of today, my car has done something twice that I’ve never seen it do before: basically I unlock the car, sit in it, and it is 100% dead. The car will not power on or start, and the open door light on the dash struggles to stay on, as well as the map lights which look very dim. I can hear some electronics trying to do their thing, while everything is off. If I try to unlock/lock the car using the fob, it will not work either. Surprisingly, after waiting a few minutes both times, the car started working normally, no CEL, or anything.
    Before I go any deeper into troubleshooting, this seems indicative of a bad 12v battery - my car is a 2015 model and I don’t believe it’s ever been changed (I’m the second owner). Thoughts/advice?
    Thanks!
    #1 15SuperPrius, Oct 27, 2019
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    yep, first thought would be bad battery /
    Raytheeagle and 15SuperPrius like this.
  3. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Thanks! Any advice on what type to get and where? Or is dealer the recommended option? I’m used to working on my own cars, but being that the Prius is a different animal, I thought I’d ask.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I got a replacement at AutoZone when it was on sale and it worked well:).
    And they have better hours than most dealers do(y).
  5. StarCaller
    1,284
    733
    for sure not from the dealer /
    check out pepboys, they might have coupons for bosch batteries or check amazon for a optima yellow top /
    Raytheeagle likes this.
  6. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Just any 12v battery, or is anything special required for the Prius? Also, where is the battery on this thing? lol
  7. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Find the model number and search for that ;).
    The battery is in the back behind the passenger rear wheel(y).
    15SuperPrius likes this.
  8. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Thanks folks!!
  9. PriusCamper
    PriusCamper Senior Member
    13,444
    5,428
    Pacific Northwest, USA
    --If you want to change the terminals that connect the wires to battery, get a Miata sized battery for $50 (25 amp-hour)
    --if want to change the hardware on the 12v so they fit on existing terminals that connect the wires to battery (bushings/longer bolts), get a mobility / backup power supply for $100-$150 (55 amp-hour)
    --if you're like all the suckers who go to the auto parts store and ask for a battery to fit a Prius for easy install ($250) (35amp-hour)
    --if you want to buy a 12v that's dead on arrival or will be dead in a matter of weeks or months, an Optima for $200 (0 amp-hour)
  10. StarCaller
    1,284
    733
    hmm, they work for me: 5 years in the prius, 14 (yes, FOURTEEN) years in the gto.... /
    bisco and dig4dirt like this.
  11. Mendel Leisk
    42,323
    No need to change cable clamps; there's lots of correct sized options.
    I probably won't go with it next time, Canadian Tire has a correct size/spec battery available now, but the Optima I put in over 4 years back is still like new, according to my tester. (y)
    StarCaller, 15SuperPrius and dig4dirt like this.
  12. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Does the yellow optima have the vent hole on the positive post side to connect the vent tube? I couldn’t see it on pictures online.
  13. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Thank you all for your responses - based on reviews and quality, I went with the Optima all is back to normal!
    Raytheeagle, Mendel Leisk and bisco like this.
  14. Mendel Leisk
    42,323
    Yes, the vent port is the same, correct orientation.
    The one thing I noticed, and I would blame Toyota design for this: the Optima is perhaps 1/16" taller or shorter (I forget which), and that necessitated the need to add a shimming washer on one side of the battery hold down bracket. It's a hopelessly short-sighted design, compared to the norm: a bar with a couple of hook-ended rods with threaded ends and nuts.
    An example of the "accomodating" design:
    15SuperPrius and Robert Holt like this.
  15. PriusCamper
    13,444
    5,428
    If your car won't start after you install it, you'll be one of many, many people who post on PriusChat with that problem... At least you'll know why. Congratulations on buying a junk battery... If you're lucky you won't have to replace it for a couple years.
  16. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Interesting - I did notice the tight fit but I did not need to add any hardware. If you are able to give the bolt side a few turns, the nut side is more flexible as it doesn't "bottom out". I ended up with a perfect tight fit. Also notice that the underside of the bracket contains a foamy surface, made to contour to the battery's surface, so a bit of pressure it ok.
    ASRDogman likes this.
  17. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Huh? Car started right up, perfectly fine. The battery has great reviews.
    bisco and ASRDogman like this.
