Help Needed! Turn Signals and Hazard doesn't work !!!
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by x3mblr, Sep 23, 2015.
  1. x3mblr
    x3mblr Junior Member
    68
    Hello everyone! I just found a nice Prius C for sale with little damage to the front right corner, no frame damage or anything, just some bodywork needed. So, after it was fixed up. I brought the car back and there is weird issue that I have - turn signals and Hazard lights dont work. When I turn it on, i can hear clicks from it, but I dont see lights blinking on the dashboard and my head/tail lights dont blink as well.
    What can it be???
    Any ideas?
    49,501
    probably some bad wiring where they fixed it, maybe something left unplugged.
    or else the fuse needs to be replaced.
  3. x3mblr
    68
    As far as I know, NO wiring was damaged. but I'll check all the connectors, they seem to be in place, but I'll check once again.Where I can find the fuse ?
    49,501
    it's either by the parking brake, or under the hood. check the o/m.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Also, if one of the bulbs is burned out, that would cause the symptom. When they put it back together, if they touched one of the bulbs, it may have worked when you picked up the car, but the acid from fingers or grease of any type would cause a bulb to burn out. And, if these bulbs are on the same circuit, it would definitely cause your issue. Hope this helps.
  6. x3mblr
    68
    I never knew that if one of the bulbs is bad, it can make whole thing doesnt work.
