Help Needed
Discussion in 'Gen 2 Prius Technical Discussion' started by kodiak1, Dec 12, 2011.
  1. kodiak1
    kodiak1 New Member
    wyoming
    HELP
    I have a 04 prius , have had no problems til now,
    it has 86k on it , while blending in with traffic on freeway , not at full throttle by the way, clear dry road, the wheel slip light will start to flash and will not go more than 60-65 mph under full throttle.
    No codes show on OBD reader.
    Tire sizes are the same. Wheels are not slipping, but indicator says they are.
    Any help is welcome, has any body else had this problem?
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Check for mismatched tire size. If one wheel rotates faster (or slower) than the others, you will have this problem.
    JeffD
  3. kodiak1
    kodiak1 New Member
    wyoming
    Thanks
    Checked tire size , both the same 185R60/15
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Suspect wheel speed sensors. A normal code reader will not pull codes for this. You need to jumper pins 4 and 13 on the OBD DLC and turn the car on to get the warning lamps to flash out 2 digit codes. Search here for more info.
  5. Patrick Wong
    18,210
    6,526
    Check the tire size on all four tires, and ensure that tire air pressure is correct.
