1. Hybrid Hobo
    Hybrid Hobo Member
    217
    55
    New Jersey
    I'm off on my first camping trip with my Prius today, and I noticed that the red passenger seat belt warning light has been blinking all day. I don't have a passenger, however, my car IS loaded to the brim with stuff, including a huge HEFTY storage bin on the passenger seat. Could that be the issue? Maybe the weight or bulk of stuff is setting off a sensor of some sort? If anyone can help, I'd appreciate it. I'm scared of the warning light running down the starter battery if I leave the car on overnight in ready mode to use the climate control, etc. Is that even possible?
  2. Stevewoods
    Stevewoods Senior Member
    666
    1,267
    where I am
    Spent most of your time on a burro in the past several years?:p
    Yep, any heavy weight on the passenger seat will cause that light to illuminate. You can always buckle the seat belt to stop it, if that makes you feel better. Same thing on my Camry. Put a gallon of milk on the passenger seat -- and light goes on.
  3. JC91006
    16,936
    8,647
    Just click/attach the passenger seat belt. Warning will go away.
    Yes it's the weight of the bin
  4. ChapmanF
    19,020
    It's not possible for the 12 volt battery to run down when in READY mode.
    At least not until after you run out of gas.
    MickyMatter and Stevewoods like this.
  5. PriusCamper
    PriusCamper Senior Member
    13,463
    5,431
    Pacific Northwest, USA
    I have had my passenger seat belt strapped in with no passengers for years... The sensor in the seat that tells the passenger to put their seatbelt on is worth keeping when you give someone a ride.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The HV battery will keep the 12v battery charged if in READY, but if you are in N, the HV battery won't charge. Keep it in P instead.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,101
    6,966
    Texas Hill Country
    The bigger issue is the short cycling of the engine as it only partially recharges the hv battery during an extended Ready mode without driving. Besides potentially waking you up four times an hour, you are thermal cycling the engine each time and are at a slight risk for carbon monoxide illness.
    Family Escapes Serious Carbon Monoxide Illness After Car Accidentally Left Running in Garage – Cardinal News
  8. ChapmanF
    19,020
    The likelihood of CO poisoning is way lower when camping out-of-doors than inside a garage as in that article. Not completely zero though; some terrain features and types of weather can do weird things with airflow, and there have been cases involving a vehicle parked outdoors.
    But simply carrying an inexpensive CO detector in the car is an easy way to deal with the (already very low) chance of such an incident in a camping Prius.
  9. PriusCamper
    13,463
    5,431
    One of the most common ways to kill yourself sleeping in a car is when you're in the snow and leave the heater on all night. There's a long history of this problem because the exhaust coming out of the tail pipe can get redirected by the snow pack and make its way inside of the car and you never wake up again.
  10. ChapmanF
    19,020
    Yes, that's one of the many sorts of terrain/weather circumstances that can make it useful to have an inexpensive CO detector in the car.
  11. rjparker
    11,101
    6,966
    Texas Hill Country
    #11 rjparker, Apr 12, 2022
  12. PriusCamper
    13,463
    5,431
    Or just have lots of blankets so you don't ever have to run your engine while sleeping... I've slept in my Prius in temps as low as 16 degrees.
