HELP! No dash lights and won't shut off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by exmetrodriver, Jan 14, 2015.
  1. bisco
    52,816
    i guess you can handle once every 30,000 miles.
  2. exmetrodriver
    exmetrodriver Member
    124
    16
    Puget sound, Wa.
    Right. Funny how is seems to go away for most people. I do want to find the issue and solve it.
    52,816
    i know, it's tough with no dtc's.
  4. PriusGuyfrom213
    PriusGuyfrom213 New Member
    L.A.
    This worked for me if your dash wont light up.
  5. Q*bertZ
    Q*bertZ Member
    167
    greenville south Carolina
    2002 Prius
    That might work temporarily but I took my dash apart and replaced the bad capacitor that kicks on the dash lights. That's what was wrong with mine. It comes with an 100 microfarads capacitor that doesn't live up to its tolerance. Replace it with a 220uf capacitor. Has been working ever since. 20210330_125030.jpg
    The correct polarity is very important. Notice the bevel on the old 100 microfarad capacitor. That's the negative side. Unsolder it and solder in the new one. Put the dash back together and it works. Alot of volt meters have a capacitance setting.
  6. ANICE
    ANICE New Member
    Langford
    I know this is an old post, but I had the same issue with my Prius. Then I found a couple of buttons under the steering column and one says 'key.' I pushed the button and lo and behold everything went back to normal. ‍♀️ My screen display came on and I was able to shut it off.
  7. dolj
    dolj Senior Member
    8,637
    4,390
    Wellington, New Zealand
    That button is the SKS disable button. Press it in to disable the SKS, press it once again to return it to the out position and it enables SKS. I don't think pressing it in has fixed your combination meter problem.
    jerrymildred likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Coincidence. The SKS button/system doesn't have anything to do with the CM. Might as well have opened and closed your door.
  9. Q*bertZ
    Q*bertZ Member
    167
    2002 Prius
    The capacitor probably just built up enough voltage to turn it on. I took my dash apart and replaced my 100uf 16v display start capacitor. Search the internet for "220uf capacitor 16v". Unsoldered the old one and soldered in the new one. 20211229_115745.jpg 20210330_125030.jpg
  10. Q*bertZ
    Q*bertZ Member
    167
    2002 Prius
    There are some videos out there. Search "combination cluster fix 2004-2009 Prius".
  11. Carboss
    Carboss Junior Member
    Colfax WA
    Replaced Dash capacitor today not that difficult to disassemble with plastic prying tool, but air vents over time became incredibly brittle and one of those did not feel like cooperating and "formed a crack" but apparently there are sets of those new available for replacement.
