HElP! no idea how to work heat! my babies are cold!
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Ashleigh12priusc, Dec 11, 2017.
  1. Mendel Leisk
    41,143
    The jetstream says it all:
    jerrymildred and ztanos like this.
  2. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    for these cold southeast Texas morning, yanno when it is 45°F, I can crank up the heat on my 2015 C to "HI", no ac selected and I get heat, lots and lots of beautiful delicious heat. :)
    Raytheeagle and bisco like this.
    51,709
    i'm glad your babies aren't cold!(y)
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Another comment that may or may not be helpful:
    With any of my newer cars, it has been almost impossible to really tell if air is blowing on the "floor" or not.
    To really determine that, you must open the door and stick your hand into the foot well and feel around a bit.
    Often the air is directed so that it does not blow directly on your legs or feet.
  5. bisco
    51,709
    your turn.:)
  6. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    Most likely as stated before, bad thermostat, fan, or something bigger within the hvac system.
    Other than that, AC can be on/off and it shouldn't affect if the car outputs heat or not, since the car's thermostat should be able to detect ambient temperature and output to cabin until cabin reaches desired temp (65 being lowest set-able). I've always had AC on anyway, since I heard somewhere that it being on does give some boost to the heat. Heat requires a warm engine and AC requires electricity, which you should have off the bat.
    ie...if it's 30 ambient and you set the car temp at 65, then car will output all the hot air it can until cabin reaches the desired 65, then car will just then maintain as needed for the 65 cabin temp
    If you have 30- winters, you shouldn't need your temp set beyond 65...because I'm sure everyone living in such a environment goes out driving in some form of cold weather gear. No point setting your butt off in your car with all kinds of coats on.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    To stay out of specifics...
    This is a "New" used vehicle.
    Sounds like something is broken.
    Hoping OP has some type of warranty. I'd get it checked out ASAP. Hope it's not serious.
  8. bisco
    51,709
    hope the o/p's fingers aren't frozen solid, and unable to type.:eek:
  9. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    515
    Outside Philly, PA
    Sounds like their computer may be frozen . . .
    bisco and jerrymildred like this.
  10. bisco
    51,709
    must be windows.
    jerrymildred likes this.
  11. ILuvMyPriusToo
    778
    515
    Outside Philly, PA
    Yes, winter is no time to have windows down!
    bisco and ztanos like this.
  12. trojanrabbit
    trojanrabbit New Member
    24
    Millis, MA
    2016 Prius c
    If the outside temperature is below freezing, the AC indicator will not turn on if you go into AUTO. You'll still get plenty of heat.
    Just before I got rid of my Honda, one of its nasty quirks was that sometimes neither heat, AC nor defrost would work as the control panel was dead, got plenty of air though. Had to whack the panel to get it to work, so likely a bad connection.
    Another one hoping the OP has a warranty on the car and can have it checked out soon.
  13. bisco
    51,709
    sorry, posting error.
  14. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Must be a change from the 2012 and the 2015-current controls. When I was in Kentucky sitting in 0 degree weather, the AC light was on just fine... but I don't ever use AUTO... it never turns off in the summers down here. :D
  15. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    No idea, my 2012 has heat that makes it hotter then hell.
  16. Prodigyplace
    12,487
    11,731
    Central Virginia
    The AC light is on for Gen 4 too.
  17. Steven Michael Giusti Jr
    Boston
    Since you bought it yesterday you have some sort of warrenty so instead of trying to figure out the many causes of what could be wrong with it from the internet you should probably take it back to wherever you bought it from and have then fix it.. just one person opinion.
    #37 Steven Michael Giusti Jr, Jan 15, 2018
  18. Sam Spade
    2,036
    1,023
    2017 Prius c
    Well then please DON'T be.
    NONE of what you said helps anybody at all.
    I have a '17 C and it is very slow to produce heat, even around 35 F.
    It appears that just starting it and letting it sit will produce almost NO heat.
    You need to actually drive it.
    dubit likes this.
  19. bisco
    51,709
    same here, maybe they decontented the newer models.:p
  20. bisco
    51,709
    of course, o/p's is a 2012, so that dispels my notion.(n)
    hmm, december 11 until january 15 is a long time to freeze your babies.:unsure:
    Raytheeagle, scona and Prodigyplace like this.
