Help. No start after maintenance
Discussion in 'Gen 2 Prius Main Forum' started by Todd Stepp, Jul 13, 2019.
  1. Todd Stepp
    Todd Stepp Junior Member
    Rio Rancho, NM
    So in the front we changed the spark plugs, cleaned the MAF, change the engine air filter, serpentine belt and idler pulley.
    In the rear, cleaned the battery cooling fan (really nasty) and changed both rear tail lights. For safely, I did remove the main battery plug (orange jumper on the driver's side of the battery.
    All back together but no codes and no start, just all the warning lights.
    Next is an oil change but cannot get it up on ramps if no power...
    SM-G973U ?
  2. Todd Stepp
    Rio Rancho, NM
    Got it... when I closed the HV plug, i forgot to press it down... (feeling like a moron...)
    SM-G973U ?
  3. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Solved your problem in 38 minutes? Sounds like you're ready to go professional!
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Easy mistake to make, particularly at the end of a long day.
    donbright likes this.
  5. Patrick Wong
    18,210
    6,517
    There was no need to remove the traction battery interlock if you were not messing with the high voltage orange cables, BTW. It’s good that you figured out how to correctly reinstall it.
    If you are concerned about safety, disconnect the 12V battery which will totally disable all electrical circuits. Then you don’t have to worry about the engine starting while you are removing the serpentine belt.
    #5 Patrick Wong, Jul 14, 2019
