Help! odd new noise
Discussion in 'Generation 1 Prius Discussion' started by bensherb, May 13, 2012.
  1. bensherb
    bensherb Junior Member
    california
    2003 Prius
    I have a 2003 prius with 184,000 miles on it, and it just started making an odd noise. When I start off from a stop I will hear a knock or tap sound that appears to be comming from the right rear roof area. like I kicked up a tiny stone or a nut falling on the roof. It is usually a single knock but sometimes it's a quick series of three or four knocks. It occurs between 23 and 29 mph and usually from a full stop but occasionally when braking to below 10 mph and accelerating back up. I've checked out the suspension, brakes and everything in the trunk area and found nothing. Has anyone else encountered this or have any clues? Thanks
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Only thing I can think of in that area of the roof that has reported issues is the spot weld area can crack right there resulting in a water leak when it rains. Hard to notice the leak as the water will run down inside the interior covers and collect in the trunk area as a little puddle.
    Check in the hatch back top corners in the valley area where the roof meets the qaurter panel. Under the paint you can clearly see spot welds and the seam where they meet. See if you have a crack there. High stress area there as you have the hatch hinges right there.
    Short of that not much else up there.
  3. bensherb
    california
    2003 Prius
    Thanks for the reply, but I don't think that's it. I have no hatchback. My car is a sedan. I couldn't find anyplace that delt with gen1 prius, so I posted here. Here's an update though; it's been a couple of days and with another 300 miles the noise is now louder and occuring at both lower and higher speeds 5-35 mph and also while cornering. It does not seem to do it if you floor it during acceleration from a stop though. Is there someting funky about the braking system that could do this? The only thing I can find posted commenting about a similer noise, happend after being parked a while. Comments were made about a brake accumulator? Never heard of one, what is it, and what does it do? Thanks for any help.
