Help! P3190 & Limp Mode after Air filter check & oil chg
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CharlesPrius, Feb 24, 2019.
  1. Mendel Leisk
    41,473
    That snorkel has spring tensioned clip holding it to the throttle body. If it's missing, it might be directly below, or rattling around atop the engine underpanel. If it's missing, believe it's item #14 here:
    Air Intake for 2010 Toyota Prius | McGeorge Toyota Parts
  2. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    I'm curious as to why you needed a head gasket job? Did you overheat the car or some other issue occur? Glad you got the code issues sorted out.
    I found that on my 2008 that the snorkel tube going to the throttle body it was also not held on very strongly.. there is a clamp but it's easy to pull off even if it is clamped.
  3. ASRDogman
    ASRDogman Senior Member
    7,599
    3,916
    You are NOT stupid! Dumb, yes. :) But we all have made mistakes like this before.
    Dumb is you don't know. We are all dumb on many things.
    Stupid is you KNOW, but you do it anyway! That's STUPID!!!! :) :)
    I am glad you figured it out and it was a simple mistake.
    It's best to go slowly and always check your work. And if you do some work and afterward you have a problem,
    then check everything and find what you disconnected, or if something came off.
    Things like this happen to the best of us, so don't feel bad about it.
    But I bet it won't happen again! :) :) :)
    #23 ASRDogman, Feb 25, 2019
  4. CharlesPrius
    CharlesPrius Member
    154
    60
    OK Thank you. I think I did yank it off, it's probably on the ground somewhere. i'll need to order a new one probably. crap. may just take it to my mechanic, seems hard to get to without a lift?
  5. CharlesPrius
    CharlesPrius Member
    154
    60
    Electric water pump failure, cyl 2 gasket blew. common problem this gen, mech said
  6. CharlesPrius
    CharlesPrius Member
    154
    60
    Yep thanks, and now i need to look for a new clamp for that snorkel... or maybe it's on the ground.
  7. kens97uber171
    177
    133
    US
    I for some reason I missed that this was a third gen. I'm surprised it didn't throw in a mediate check engine light when the pump stopped? Or was it perhaps a leak.
    One of the things I love about the app.
    hybrid assistant. Is that it gives you some temperature outputs from engine, inverter, and MG2.
    If anything is outside of its normal range they turn red. You might consider looking into that app. It also has the ability to override the factory settings on the cooling fan for the battery. And you can set criteria for the fan to come on at a lower temperature. This is extremely helpful if you live in a very hot climate. It also helps warm up a battery in extreme cold. Because it will turn the fan on to a low setting to bring in warm cabin air to get the battery temperature up quicker.
    CharlesPrius likes this.
  8. Mendel Leisk
    41,473
    You could use one of these till you get the proper clamp:
    The Toyota clamp has a tricky mechanism, so you can lock it in the expanded, loose mode. You pinch the tangs with pliers, then kinda wiggle it into the locked position. Get the clamp positioned properly, then release it from the locked position, and it'll clamp tight. I never find it easy, various types of pliers are worth trying. I find a somewhat wider tipped pair of pliers easier to work with, hard to explain.
  9. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    That’s the exact hose I was talking about
  10. ASRDogman
    7,599
    3,916
    Usually what I do is watch 5 or 6 videos from youtube. Each one is different. Some are really worthless!
    But I've found each one has something the other doesn't. So you can learn any tricks.
    After you watch them a few times, you feel you know how to do it.
    It makes it easier to do.
  11. CharlesPrius
    CharlesPrius Member
    154
    60
    The clamp to which I was referring in that query (wrt whether it goes around the outer movable sleeve or the main hose in front of it) is being pointed to here. I could only get the clamp to fit around the smaller hose in front of it; I don't see the point of the sleeve, but i'm sure it has a purpose?
  12. CharlesPrius
    CharlesPrius Member
    154
    60
    Thanks. The spot I'm referring to wrt to this clamp is pointed to in this photo. This hose seems to fit snugly over the top of the metal (aluminum?) throttle body opening, and to be held on by the weight of the air box/hoses -- it's hard to pry up without unclasping the air box and yanking. Unlikely (though possible given my dummasery) that I ripped a clamp completely off of this joint while checking the air filter, never to be seen again. So if there is supposed to be a clamp there, my guess is that the guys who replaced the head gasket 12k miles ago forgot to put it back on.
    #32 CharlesPrius, Feb 25, 2019
  13. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The first time I cleaned the oily goo from under the TB on my Prius, I forgot to plug the TB back in. The engine doesn’t idle fast enough to keep the battery charged when you are driving. It took the second time of going into limp mode for me to realize the ICE wasn’t revving when I pushed on the pedal.
  14. Mendel Leisk
    41,473
    ^ That's a pretty disastrous situation. Firstly because completely unfiltered air has free access to the throttle body, and the gritty plumbing directly above is going to rattle some dirt in as well. Also, the Mass Air Flow Sensor is cutting checks it can't cover.
  15. CharlesPrius
    CharlesPrius Member
    154
    60
    Surely yes, and that was the reason for 3190 & limp mode. But as i said, once i realized that was the problem, i fitted the hose back correctly, and it's fixed. Been driving it for two days now with no problems
    Slider2732, kc5dlo and Mendel Leisk like this.
  16. andy stark
    andy stark New Member
    new orleans, la
    For anyone searching, I had the "Check Hybrid System" message after replacing my air filter, I re-seated all the hoses, still no luck. Then I dug the old filter out of the trash and reinstalled that, everything was fine. Turns out my Prius did not like the ACDELCO A3686C air filter that I bought for $9.99 on RockAuto.
  17. ASRDogman
    7,599
    3,916
    Perhaps the delco one was too restrictive?
  18. Brian1954
    Brian1954 Senior Member
    2,217
    873
    South Central PA, USA
    Did you read the trouble code when you got the "Check Hybrid System" message? If so, can you please tell us what it was.
    Did you purchase a different air filter that worked without triggering a trouble code?
