Help - PiP seemingly dead
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Saarp, Dec 1, 2012.
  1. Saarp
    Saarp New Member
    Seattle, WA
    I have a PiP I picked up last April. It has been sitting in the garage plugged in to the charger since last weekend. I went to drive it yesterday and it was completely dead. "No big deal", I thought, "just a dead 12v battery".
    This morning I went to jump the 12v battery with the charge points under the hood and nothing. The car is stuck in my tiny garage and everything is electronic so I can't even put it in neutral to push it out.
    At the dealer where I bought it the service department is too busy to pick up the phone. Does anyone know what could have caused this? I am not sure what else to try.
    Thanks in advance.
    Andyprius # 1 likes this.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    try letting the 12 volt battery trickle charge overnight. connect the trickle charger directly to the battery located in the cargo area
  3. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Call Toyota Care
    52,854
    both good suggestions.
    Adam Leibovitch likes this.
  5. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I like mine better. Service Depts aren't experienced yet.
  6. bisco
    52,854
    i'm not sure what toyota care will do?
  7. lensovet
    2,615
    496
    Burlington, NJ
    Did you try jumping the car by connecting directly to the battery in the back?
    Also, what if you unplug the charger and then plug it back in?
  8. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I just call Toyota Care (Toyota Customer Experience Center) 1-800-331-4331
    Selection 1 is Roadside Assistance.
    Selection 5 is General Questions about Product or Dealer.
    Roadside Assistance will pickup your car and bring it to the nearest dealer of your choice to get fixed.
    General Questions has some technical assistance that may fix the known problems. If they can't fix it, they will get help from the dealer.
    The guy I spoke to said he could walk the caller to get the car started.
    So Saarp, give them a call.
  9. lensovet
    2,615
    496
    Burlington, NJ
    OP said car is stuck "in a tiny garage". Not sure how he's going to be able to get it towed out of there.
  10. bisco
    52,854
    the 'walk thru' on the phone sounds like a good idea.
  11. 3PriusMike
    3,101
    2,421
    Silicon Valley
    You would have to jack up the front and insert rollers under the front wheels. Then release the parking brake for the rear wheels to move. Then push or winch the car out. If the driveway rolls downhill the "driver" needs to be ready to brake. Then load onto flatbed tow truck. A good tow truck operator will know how to do this.
    Mike
    JMD and WE0H like this.
  12.
    JMD likes this.
  13. Good suggestion Ken, everybody can use this info. Thank You for going to the trouble.
  14. Hopefully, you will give us a good follow up on this. As far as I know, this is our first serious problem with a PIP
  15. Plugged into the charger since last weekend. Sounds like the charger gave out, thereby also not keeping the 12V charged, along with a current drain on the 12V. Wild guess!
  16. Do you have a multimeter?
  17. Funny how these things always happen around a weekend.
  18. lensovet
    2,615
    496
    Burlington, NJ
    well, the charger shuts off as soon as you have a full charge. it doesn't "recheck" the charge state until you unplug and plug back in.
  19. It sounds like the old 12V problem, again!
  20. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Don't you hate it when the OP doesn't even bother to post the outcome or even acknowledge this thread after posting it?
    southernguy and bisco like this.
