Help - PiP seemingly dead
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Saarp, Dec 1, 2012.
  1. lensovet
    2,615
    496
    Burlington, NJ
    Lol not everyone sits on this board all day like some of us. OP posted this morning! Give him time.
    OceanEyes and Andyprius # 1 like this.
    52,791
    yup.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    maybe he connected the jumper cables to the battery in reverse and is in the hospital:whistle:
    52,791
    and they took his phone away.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    or his tablet
  6. Saarp
    Saarp New Member
    Seattle, WA
    Hi all. Thanks for all the suggestions and sorry for not posting more a more timely response.
    Here is the day 2 update:
    I was able to open the rear hatch by crawling through the back seat manually releasing the latch thanks to the owners manual. This gave me access to the 12v battery. I also called Toyota Care since I have the roadside assistance. On the phone they were not very helpful. The call took almost 30 min an they had no mechanical knowledge of the car. They couldn't even find my address so they gave the tow truck driver the address of a local supermarket. Unfortunately they also gave him my wrong phone number even though they sent me a confirmation text to my correct phone. Good thing I called because he was about to head back.
    Anyhow, so the driver managed to wedge the truck into the driveway and hooked up the cables directly to the 12v terminals - no response. Nothing came back. He also mentioned that he wouldn't be able to get rollers into the garage to get the car out. If it can't be put in neutral, he didn't know how to get it out.
    One other thing I noticed is that the GFI where I have the charger plugged in had been tripped, though the GFI built into the charging cable had not. I reset it and tried plugging the charger back in - no response.
    I will try calling Toyota Care again today. Im also going to check the battery voltage directly and the fuses since this seems like it may be a more complicated problem. Right now I have an expensive brick sitting in my garage. :(
    Thanks for all the suggestions.
    JMD likes this.
  7. WE0H
    WE0H Senior Member
    3,247
    528
    They could spray some lube or liquid soap on the floor so the front tires slide easily and pull it out with the winch.
    Mike
    Mobile on my SGH-i717
    JMD likes this.
  8. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    So maybe the household current failed
    WE0H likes this.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Too bad you cant take that expensive brick and throw it thru Toyotas window lol
    LG-MS910 ? 2
    lensovet likes this.
  10. JMD
    3,779
    1,282
    Please keep us posted on the outcome
  11. JMD
    3,779
    1,282
    How old is your house? Can you tell us anything about the electrical in the home?
  12. Saarp
    Saarp New Member
    Seattle, WA
    It's certainly not a house wiring thing. House was built 7 yrs ago. Nothing else in the house was affected.
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Did the fuse or breaker in your house blow also or just the gfci?
    LG-MS910 ? 2
  14. Saarp
    Saarp New Member
    Seattle, WA
    Just the gfci.
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    interesting.....something shorted out to ground but not enough to blow the breaker
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    does the led on the brick still come on?
  17. if the 12v is low, the car usually will not come on at all, you can take the 12v out and charge on a bench for 24 hrs+ If the 12v is totally shot, you will not be able to charge it? While the 12V is still installed, try to jumper either front or back, also press power 2-3 times to reboot. There is also a 100 amp fuse in the area of the positive cable, that may have blown.
  18. Because either at the point of plug in or before it the EVSE only sensed an open, simultaneously, there was a big current drain for one week OR the 100 Amp fuse blew by the Pos cable. = no future start-ups. My WAG.
  19. Without knowing the SOC of the 12V, we are going blind.
  20. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    That has happened to me twice. It was able to be brought back after two jumps to the rear 12v terminals. I'd be very interested if you find a solution.
