Help - PiP seemingly dead
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Saarp, Dec 1, 2012.
  1. John H
    John H Senior Member
    2,208
    558
    What might work is to use entune to start a charge once a day so that the circuit activates and freshens up the 12V battery. What happens if you use entune and the HV batttery is already at a full charge? Will it still spend a few minutes charging or will it just ignore the request?
    once the 12V is dead, I think your toast and can't use entune.
  2. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    I found when the car is fully charged, but the 12v is dead, replugging in the evse does nothing. It won't charge because it is full or because the 12v is dead it can't detect that the evse was inserted. There are many band-aids to recover when it happens, but I want to see it fixed. I have heard of 3 people who had this issue without a load on the battery.
  3. 3PriusMike
    3,101
    2,421
    Silicon Valley
    The reasoning for that goes back a ways. The idea was how to easily explain a safe way to jump start a vehicle with a dead battery. The decided procedure was that you should connect the negative to the engine block, away from the battery...even though, electrically it is just as good to connect right to the negative connector on the battery. The reason is that when you have a dead battery, especially, a couple of decades ago you may have have a non-maintenance free battery and opened the cells and checked the electrolyte levels. Some procedures even had you opening the cell caps and covering with a cloth. This is because charging generates hydrogen gas, which at the right level can explode. If you "removed" the jumper cable, with a lot of current flowing AND the hydrogen level was high enough AND a spark jumped from the jumper cable to the battery you could ignite the hydrogen. But if you were connected 2 feet away or so this wouldn't happen.
    So don't worry (much) about this when you haven't been vigorously charging your 12v battery and you aren't connecting or disconnecting a cable with lots of current flowing.
    Mike
    rogerv likes this.
  4. John H
    2,208
    558
    Can you do a remote start or "cabin conditioning" with entune? IF so, it might energize the PiP into "Ready" and refresh the 12V from the HV battery. Doing a daily, or semi-daily, remote start/freshen might keep the 12V from draining all the way down.
  5. lensovet
    2,615
    496
    Burlington, NJ
    Yes, this would work. But only on the advanced model. Which, incidentally, will also drain the 12 V battery quicker, since it keeps its cellular radio on all the time. Actually, I wonder if that's the issue? That if the car is parked in an area with a very weak/no signal, the car ends up draining the 12V battery way too quickly as the cellular radio tries to find a network in vain?
  6. John H
    2,208
    558
    If this problem is only happening on the "advanced" model, I would suspect the communications link (cellular radio). Another culprit to look for would be bluetooth radios that get stuck "on" searching for a phone to connect with.
  7. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    In my case, I have a basic, and I don't use Entune or a smart phone at all.
    John Hatchett likes this.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    but you do have keyless entry which is running all the time:cry:
  9. Mendel Leisk
    42,347
    Over the years, whenever I've had to hook up to a 12 volt battery, either to jump/charge, or just checking the voltage, I'll just blow once or twice across the top of the case. Can't hurt ;)
    3PriusMike likes this.
  10. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I try to do this door locking "best practice" in garage, but when I gave out this same advice I got corrected that this does not snuff out all battery drains. Of course, in Gen2 we have the SKS slow drain which can be switched off.
    PS- I am under the impression Gen3 have much less SKS drain
  11. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    It's been moved into the Vehicle Customization settings in the navigation. See pg. 640 of the Owner's Manual.
  12. lensovet
    2,615
    496
    Burlington, NJ
    oh wow, good call. good news, no need to pull fuses!
    if you have tech stream/torque/scangauge, you can also turn off remote a/c and wireless key entry…
  13. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    If we're gonna be totally accurate here, it's the inverter that charges the 12V battery.
    lensovet likes this.
  14. Saarp
    Saarp New Member
    Seattle, WA
    Hi all,
    So on Wed I took the car down to the dealer to look into the problem and perform the 5k service (which they insisted was NOT an oil change :) ). The found a .9mA draw on the battery and nothing to explain why it would completely discharge. All the same they replace the battery for me. I don't know if there were any computer codes. The invoice said the battery had a bad cell.
    I do have the Advanced model with Entune. I really just wanted the fake leather seats but it came as a package. I really like the seat and wish they came in a color other than black, but that's a different topic.
    I don't know what the SKS is or why it should be turned on/off. I wasn't even aware that the plug charged the 12v as well as the drive battery. It's true that when the 12v is discharged, the car will not charge through the plug charger. It needs enough power to "sense" the plug and won't charge with the computer down.
    In any case, I'll be making an airport run tonight so we'll see how it goes. Hopefully this is the end of this saga for me and that others are not encountering this on a regular basis.
    BTW, has anyone tried a trickle charger that feeds back power through the cigarette lighter? Do these work?
    Thanks.
  15. John H
    2,208
    558
    I don't believe the "cigarette lighter" is on when the car is off so the trickle charger doesn't work unless you connect directly to the 12V battery terminals.
  16. bisco
    52,855
    sks is the system that allows you to enter and start your car with the fob in your pocket, purse, etc. there is some draw, but not much if it's working correctly. i have left my 08 for upto 6 weeks at a time with no issues. the pip may have other things going on, i don't know. as far as a trickle charger, i don't know about the lighter socket, but there are charging posts under the hood you can use. hopefully, you won't need them. all the best!
  17. lensovet
    2,615
    496
    Burlington, NJ
    okay, so SKS = smart key system, which bisco already described.
    you mentioned you left the car in the garage. how is the signal there? i believe Toyota uses Verizon for the service.
    honestly, at this point i suspect SafetyConnect/Entune is the culprit here. perhaps along with a shot battery.
    keep us posted and have a good trip!
  18. One cell bad. Definitely a bad battery to start with. Access socket is only live in Acc or ready mode. Keep car locked at all times, then you can be assured that nothing is on or forgotten . .9ma = .ooo9 Amperes. That's tiny.
  19. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Saarp,
    The dealer is correct; there is no oil change at the 5K interval, but rather an inspection and top-off of fluid levels and tire rotation. Oil changes are at 10K service intervals.
    trentofdestiny and lensovet like this.
  20. the SKS is not Running all the time, it is on standby, but the SKS and car are only communicating within a very short range, probably 3 ft. Or less AND only really actuated when the door handle is touched.
