Help Please ☹️ Quit Again While Driving
Discussion in 'Gen 2 Prius Main Forum' started by Elisa daSilva, Aug 15, 2020.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Under normal circumstances......................
    Do you REALLY not understand what I was trying to say ??
  2. Elisa daSilva
    Elisa daSilva Junior Member
    66
    17
    Biloxi
    For other people that might work, in general or not it won’t work for me specifically because where I park my car cannot reach an interior working outlet.
    Calm down. I was just explaining to you why your suggestion won’t work for me. I’m sure it’ll be useful for others.
    52,862
    no chance...
  4. Elisa daSilva
    66
    17
    Biloxi
    I feel like that should be the Official slogan for 2020.
    edthefox5 and bisco like this.
  5. bisco
    52,862
    you and me both lady :(
  6. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    They say 20/20 in hindsight...little worried the asteroid or comet is 2021...☄️
    edthefox5, Elisa daSilva and bisco like this.
  7. Elisa daSilva
    66
    17
    Biloxi
    Update: I finally got it charged and turned on. Drove a mile and voltage stayed above 14. Checked the inverter overflow thing while car on. 62B459DD-3AFD-47C4-9F60-2542A6F7F87E.png
  8. bisco
    52,862
    looks bad from here
    edthefox5 and Elisa daSilva like this.
  9. ChapmanF
    19,027
    On my screen, nothing is moving. Wait ... :)
    It also doesn't look very ripply.
    Elisa daSilva likes this.
  10. Elisa daSilva
    66
    17
    Biloxi
    I tried to upload a video but I couldn’t. Yeah, there is zero movement. Now, I’m trying to find the fuse that controls it.
  11. ChapmanF
    19,027
    Seems like I hear "AM2" mentioned a lot in pump-related stories.
    On the other hand, I don't think I've often heard the fuse is the culprit in the story. Seems it's usually the pump that goes south, and if the fuse is blown, it's because the pump took it out.
    VFerdman and Elisa daSilva like this.
  12. Elisa daSilva
    66
    17
    Biloxi
    I’m wondering how to tell if it’s the pump or the inverter.
  13. bisco
    52,862
    the codes have it
  14. Elisa daSilva
    66
    17
    Biloxi
    ? I only had one code.
  15. bisco
    52,862
    what was it for?
  16. Elisa daSilva
    66
    17
    Biloxi
    P0A93
  17. bisco
    52,862
    see the luscious garage youtube video
    edthefox5 likes this.
  18. Elisa daSilva
    66
    17
    Biloxi
    I have watched it like ten times today
  19. bisco
    52,862
    whats the problem?
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Bad pump. Pull the bumper down like Luscious.
    Bumper pull down works great real fast then you pull the headlight assy out and the pump is right there for the taking.
    Your going to need that technique anyway to change the bulbs in the headlights eventually. The secret to the bumper is the hidden little bolt that holds the edge of the bumper on. Its inside the wheel well very close to the seam where the bumper meets the fender.
    Once that bolt is out and the top bolts are out just pull on the bumper seam it will pop right out.
    Only caveat is at this age of the car where everything is old and brittle it will almost certainly break the little plastic pins on the black plastic track that grips the bumper seam. You cannot get the headlight assy out without pushing the bumper down.
    Ive heard of people on this site that got the pump out without removing the headlight assy but looks very hard.
