Help Please ☹️ Quit Again While Driving
Discussion in 'Gen 2 Prius Main Forum' started by Elisa daSilva, Aug 15, 2020.
  1. Elisa daSilva
    Elisa daSilva Junior Member
    66
    17
    Biloxi
    The problem is that I am very tired. Nothing makes sense anymore. You’re talking about the repairing one, right?
    I think I need to find the part? Where’s the most inexpensive place?
    52,862
    replacement, not repair. check camelback toyota
    Elisa daSilva likes this.
  3. ttou68
    ttou68 Active Member
    351
    211
    Search Amazon for Prius inverter pump, pretty good price and 2 day shipping..
    Replace it and AM2 fuse should get you back on the road..
    #63 ttou68, Aug 20, 2020
  4. ChapmanF
    19,027
    It's generally the inverter saying "I'm not happy, I'm too hot, taking a nap now" but because of the pump. Working pump, happy inverter.
  5. Elisa daSilva
    66
    17
    Biloxi
    I’m saying the same.
  6. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    @Elisa daSilva, sounds like you are on your way to success. Bad pump is less bad news than bad battery. Get some rest and replace the pump. It's supposed to be fairly easy. I have not done this yet, so can't say from experience. But watched videos and am confident it's a simple job. Also a lot less money than even a 12V battery. Good luck!
  7. Elisa daSilva
    66
    17
    Biloxi
    Thanks so much!
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Theirs more to it than the pump though. You have to dump the Inverter coolant that's a big bolt under the car right next to the trans dump bolt then have to fill the Inverter coolant system back up with 2 gallons of toyota LLC then take the plastic cover off the rad and bleed the coolant
    of any air lock.
    There's many you tubes on it. Also use the search forums tab up top and search
    inverter coolant pump
  9. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    Your Prius didnt like it when you dirtied up her hiney with all them dirt and leaves. :giggle:
    Hopefully that solves it and you don't have the headache of replacing the pump and THEN having to do that damn hybrid battery and THEN having the 12V crap out and THEN having to get a hybrid battery all over again like I had to.
    I got so pissed I wanted to drive my Prius into a freeway wall, then I realized that this isn't the Indy 500, and I don't have the sponsors to pay for a new car...
    ...I just ran around in my underpants for a bit.
    edthefox5 and Elisa daSilva like this.
  10. ttou68
    351
    211
    Actually, you don't have to drain coolant to do the pump swap..
    Loosen driver side bumper, remove driver's side headlamp, clamps the hoses to inverter pump with hose clamp.. you lose minimal coolant..
    However, it's a good idea to change the coolant if it hasn't been changed the past 100k miles...
  11. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Just guessing here but thinking it’s never been changed.
  12. Elisa daSilva
    66
    17
    Biloxi
    Where is the door jamb fuse?
  13. Elisa daSilva
    66
    17
    Biloxi
    Probably. I bought a gallon+ of antifreeze already diluted when it died because the engine coolant was low. Is that the same as the battery coolant?
  14. ChapmanF
    19,027
    The battery is in the back of the car, and air cooled.
    The coolant for the inverter and transmission is, yes, the premixed Toyota SLLC, same as for the engine.
  15. VFerdman
    1,200
    1,218
    You have to use the pink coolant in both the engine and inverter circuits. You can buy expensive Toyota stuff or less expensive stuff at auto store or Walmart. As long as it's the pink stuff for Asian cars. It will say so on the bottle. Battery is not water cooled. Just the inverter. You may need more than a gallon. Watch the YT on this. I have not done this, so no experience. It can be difficult to get the air bled out, though the inverter circuit is easier than the engine one.
    All the fuses are under the hood in the fuse block, I believe.
    Good luck.
  16. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    Fuse Box Diagram Toyota Prius (XW20; 2004-2009)
    The door jamb is tied to DOME and the security and safety system (headlight off from lock, smart key (if so equipped) etc. From your key and outside of the car, does your car lock/unlock from the remote?
  17. Elisa daSilva
    66
    17
    Biloxi
    I don’t see anything that says dome.
  18. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    It's number 17 on the engine compartment fuse list from the link I sent you.
    SFO and Elisa daSilva like this.
  19. Elisa daSilva
    66
    17
    Biloxi
    NM. I see it’s in the engine group,
  20. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    Yeah, just pull and test for parasitic draw again. If its gone, then you know that and associated systems are the cause (and makes sense if its smart key functioning). However not sure what the normal draw would be, hope someone here can chime in
