Help please. 2012 hybrid-c
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Duane75, Aug 7, 2022.
  1. Duane75
    Duane75 New Member
    Palm Coast Fl
  2. Duane75
    Duane75 New Member
    Palm Coast Fl
    I just replaced the cooling fan and switch last week and now this. It runs but the engine keeps running and doesn’t go into battery mode?
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    read the codes
  4. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    It's probably the hybrid battery. You need to read the codes but it is most likely the hybrid battery, 1 or more modules have failed.
  5. bisco
    52,752
    which cooling fan?
  6. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    I guess he meant the radiator cooling fan.
  7. bisco
    52,752
    the only one with a switch is the cabin fan, but i may not be defining 'switch' correctly
  8. Duane75
    Duane75 New Member
    Palm Coast Fl
    I replaced the coolant fan by the radiator and it has a speed control switch. The car runs fine. It just won’t switch to hybrid mode it’s suppose to. I’ll know more tomorrow when I get it to the mechanic
  9. Duane75
    Duane75 New Member
    Palm Coast Fl
    Instead of switching to hybrid mode when in park it seems the gas engine goes to a lower idle. Seems like it could be a number of things. I bought the Prius c 2012 last April. Paid $7000 for it with 110,000 miles. Now it has 146,000
  10. Duane75
    Duane75 New Member
    Palm Coast Fl
    He said the problem is because I need to fix the abs brakes and that’s what is causing a cell not to charge.
  11. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    Can you provide a video of the dash lights and the engine running?
