Help! Please identify what part this is...
Discussion in 'Gen 3 Prius Technical Discussion' started by FabianG43, Feb 17, 2013.
  1. FabianG43
    FabianG43 New Member
    It was hailing pretty bad few weeks ago and the Mrs. Came home with some damage to the rear driver's side wheel well. A part/piece was broken off, she must have unknowningly hit something. I'm not sure what the name of the part is or it's function. Would also like to know if it is important so I can replace it. Attached are pics. Passenger side has the part still attached which looks to be some kind of bracket. It is made of plastic. The other pic obviously shows the bracket missing. Please advise. image.jpg image.jpg
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    It appears to serve as a deflector of sorts. Right now, mine is holding a bit of frozen mud in place.
    There might be an aerodynamic purpose to be served, but it's probably pretty minor. It might protect the edge behind it from gravel damage.
    This might be a good junkyard pull if you have such resources nearby.
  3. PriusCamper
    PriusCamper Senior Member
    13,475
    5,440
    Pacific Northwest, USA
    I think they call them Splats... Helps improve aerodynamics....
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Not sure of the name but helps direct airflow away from the tires
  5. Catalinux
    Catalinux Junior Member
    43
    Romania
    2013 Prius Plug-in
  6. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Its an emergency escape hatch for the gerbils.
  7. Mendel Leisk
    42,373
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    Is that what is all over the road, Splats! :)
  9. FabianG43
    Thanks everyone
