1. Logangogarty
    Logangogarty Junior Member
    31
    I went into Wal-Mart for about 20 minutes and came out to my 2007 toyota prius touring and nothing would happen when I pressed the power key. No lights or anything. I went into Wal-Mart and had the service center do a portable jump and everything was fine after that. I drove around turned off the car and then let it sit for more than 30 minutes. I came back out and did the voltage check on the MFD and I had good readings 12.2V and then up to 14 when I started the car. I had Auto Zone test the battery and alternator and they said both looked good. I parked the car and the following morning I got all the lights on the dash with the message Problem with Transmission P locking mechanism park on flat surface and apply parking break. I hit power again and the car started fine. I took it to Toyota I haven't been to the dealer in years hoping they knew something. They tried to diagnose it and came up with nothing. Said the battery was good.
    Any ideas??
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    how old is the battery?
    I would replace it if it's over 4 years old.
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    only thing I can add is the prius doesn't have an alternator. if the battery is original, definitely replace it, even if they say its good.
    52,776
    12.2 is low. you can try putting a charger on it and see if it hold, but you might need a battery. unfortunately, walmartz and toyota dealers don't understand the prius battery.
  5. Patrick Wong
    18,210
    6,517
    Replace the 12V battery now. If the car could not start until it was jumped, obviously the 12V battery is not doing its job.
  6. Logangogarty
    31
    Replaced the 12v with a yellow top battery on amazon for $145 shipped car seems to be running great now.
    PriusC_Commuter and bisco like this.
  7. bisco
    52,776
    congrats!(y)
