Help please
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DigDoug, Nov 8, 2019.
  1. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    While driving to work this morning my Prius beeped and gave me some scary messages via the dash. I am trying to figure out how to post the photos on here but all the warning lights were on including the red triangle with exclamation point. Any ideas out there? 7F03ACAA-A5B9-45D0-A6D4-CC756F8BF841.jpeg
    52,855
    you have to have the trouble codes read to find out what the warning lights mean.
    can be a lot of things, engine, battery, tranny, inverter pump, etc.
    how many miles on her?
    jerrymildred and SFO like this.
  3. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    I don't have an exact number but around 200 K. I have my local garage checking the codes out. I am waiting for them to call me.
    Raytheeagle and bisco like this.
    52,855
    if they don't have tech stream diagnostic software, the codes may or may not be correct
  5. George W
    George W Senior Member
    939
    520
    San Antonio
    A $11 code reader, paired over Blutooth with a free app like Torque Lite, will give you so much more information that we might help to better assist you. If you paid the App Store a couple of dollars for the 'Pro' version, you could reset the error codes and see which ones duplicate.
    #5 George W, Nov 8, 2019
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I think it would be a safe assumption it's probably a P0A80 code to "replace Hybrid Battery".
    That's just based on you being in PA, the weather being cold, it was first thing in the morning after it sat all night, and of course, it probably the original HV Battery..
    in addition...the READY light is still lit, which means you can still drive the car normally, just a bit more gently
    jerrymildred, edthefox5 and SFO like this.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Not sure I agree with that advice.
    All the warning lights were on....including the red triangle of death. IMO the ready light being on doesn't override these warnings. Best to NOT drive the vehicle as much as possible until exactly what is wrong can be determined.
    Not saying this was the case for this particular event. In fact it sounds like it was NOT..but...one of the most frustrating things that seems to routinely happen is when a vehicle...Prius or otherwise, gives multiple warnings that something is wrong, but people inexplicably just keep on driving.
    Then 20, 40 100 miles or more when they have a major breakdown, they are going.."Gee, What Happened?".
    To me?
    You've got a Christmas display of warning lights?
    The best thing to do is to NOT pass go...but ASAP determine what is happening, and drive it as little as possible in the interim. The "ready" light in the face of all the warning light is not a signal that the vehicle is at all good to continue to drive.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Yup its probably the hybrid battery. See the little icon in the upper left of the mfd that's the hybrid battery. fault. Ground fault or delta..
    You my have noticed poor mileage and no power. have to keep close eye on battery charge behavior on the mfd on these old cars.
    Becoming number 1 post on the G2 forum.
  9. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Anyone knows of an inexpensive fix? I'm not looking forward to replacing the battery at the dealership's prices. Or would I be better served with looking at another car?
  10. bisco
    52,855
    depends. you can look for an oem around 2k, an aftermarket at $1,600. or just replace some cells and rebalance.
    what is your level of diy skill?
  11. George W
    939
    520
    San Antonio
    I pondered this same question as my HV pack slowly got worse. I don't have the tools to recondition, so that option was out. When I weighed the difference between a Green Bean reconditioned pack ($1350) , or converting to NewPriusBatteries Cylinder batteries ($1600), I opted for the New. The process wasn't hard, just detailed. I spent a whole day making the conversion, and am looking forward to years of worry-free miles.
    jerrymildred and Tim Jones like this.
  12. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    This is my reference.....just saying the car can drive normally, not saying he should go out and have a driving party....
    kenoarto likes this.
  13. The Electric Me
    9,083
    5,801
    Well if I'm reading that chart right....
    First of all it's coming from a specific and known code...P0A80...the op hasn't yet gotten the codes so it's unknown. It very well be that code once known...but at this point it's all just warning lights.
    Secondly...
    I'm reading "Driving Condition"...in other words...the car has a ready light and appears to be driving "normally"...but that isn't a declaration that the vehicle, can or should be driven "normally". In other words, it's not saying "ready light=you can or should continue to drive normally".
    IMO once you have warning lights....the car isn't "normal" even if it has a ready light and is not showing any outward symptoms.
    Especially if you have yet to have codes read, or revealed.
    Bottom line to me is...the best approach is warning lights? Strive to STOP driving until you discover exactly what the problem is....too many people just don't do this.
    I've read too many threads where someone will say that a warning light came on...hours, days, weeks sometimes months ago...they kept driving because everything seemed OK...then they are shocked when their vehicle has a catastrophic failure.
    Therefore, I'm not telling the OP the vehicle is OK to be driven "normally"...best approach? Find out what's wrong 1st, and try to do so without taking the vehicle on any long road trips...just do it ASAP.
  14. George W
    939
    520
    San Antonio
    Sell it to me cheap, and I will
    I chuckled a little bit at your explanation. I came across many Sellers who would say 'that warning light' or 'this warning light' has been on it for months, but it still drives normally. I walked away from all of those.
  15. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I guess the main difference here is that I more or less told him what the Toyota Repair Manual said for (an assumed best guess) P0A80, not some folklore I pulled out of my butt.
    dolj likes this.
  16. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    I guess the main difference with current experience working on these cars and not.
  17. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Welp I guess I need a new hybrid battery. I have called the two local dealership's to get their prices and have heard nothing back. I may just go online and buy one of the batteries mentioned above and see how badly I can screw it up. I thank you all for the input. I will ask can we please not argue over the matter? I had the codes cleared and drove the car home around one and a half miles without the codes tripping again. I also purchased the reader mentioned above and will read the car again when it comes. I can say that I will be renting another car in the interim as I need transportation and the scooter doesn't do too well in the cold. Once again, I thank you all for the help.
    edthefox5 and bisco like this.
  18. bisco
    52,855
    you can ask...
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    If you can pull the 12 volt and reset it and you can drive around the hybrid battery has a high voltage leak to ground it will then throw a ground fault nag. Basically its got a cracked battery cell leaking electrolyte and conducting to ground or severely corroded interconnect.
    Be careful though driving it there's reports of loud bangs in the battery pack from driving with ground fault.
    There's literally thousands of post about battery repair and replacement. Use the search forums button up top search and
    hybrid battery
  20. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Thank you, I shall do so. If I may ask again which is the preferred company to purchase from amongst those of you who have done this?
