Help please
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DigDoug, Nov 8, 2019.
  1. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Currently, there are only two sources of genuine new modules for a Prius, one is after-market and the other is Toyota.
    For the after-market option, buy direct from the seller newpriusbatteries.com
    For OEM, shop around the most local (as you will need to pick-up, they don't ship) dealers and see what deal you can negotiate, assuming they agree to sell to you over the counter.
  2. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    I am taking that the Greenbean lifetime warranty thing is not a good deal? I have been looking at threads and it seems to be a not so good option.
  3. dolj
    dolj Senior Member
    8,646
    4,397
    Only if you want a short-term solution and continuous hassles.
    Greenbean is still a collection of old second-hand modules. A better idea is to get the gear and do it yourself. At least this way you will ensure it is done the best way possible and when (not if) it goes bad again, you have no-one to blame but yourself.
  4. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Fair enough, I thank you for the input and will be ordering from New after I hear from the dealerships tomorrow.
    dolj likes this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    There's lot of hybrid battery "rebuilders" out there especially on craigs List. They just us the same vintage year and tiredold battery's you already have and discharge them and recharge them and that wakes them up for a while and will last for a while......until they fail again and then the whole battery box has to come out again and what a hassle.
    The only place to get brand new battery's is from the dealer or newpriusbatterys which use aftermarket cylindrical battery's that you have to swap into your existing case. Your basically rebuilding the battery yourself unless you buy the battery from a Toyota dealer. if you buy the battery form a toyota dealer and take it home you still have to remove the original battery ecm out of your old battery and install it in the new battery and then bring that old battery box back to the dealer to get your core chage $$$ back..
    What is your diy skill level? Feel comfortable around 200 volt battery box swapping parts? if not make sure there's labor $$$ on top of whatever plans you make. Nothing is a plug and play here with the hybrid battery.
  6. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Welp the dealerships are way too expensive so I am now ordering from New, Wish me luck y'all
  7. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Did you get the codes? Did you check your $200 12v before you spend $2000 on the HV?
  8. bisco
    52,855
    Please keep us posted, all the best!(y)
  9. edthefox5
    10,096
    4,837
    Clearwater, Florida
    yeah there nuts down here too like $3500 + labor. there's a waiting list at the dealer I bought my car from.
  10. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Welp I ran into a little mistake, I lost one of the left bracket bolts under the back seat, there are 7 of them should I rip out the back seat to find it or no?
  11. dolj
    dolj Senior Member
    8,646
    4,397
    The back seat is clipped in on two clips, it takes 2 secs to remove the rear seat.
  12. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Thank you. The other operator error is that I closed the hatch with the twelve volt battery removed. Time to do some climbing I guess
  13. George W
    George W Senior Member
    939
    520
    San Antonio
    Dang. That's inconvenient. I bet you'll never do this again :(
    edthefox5 likes this.
  14. dolj
    dolj Senior Member
    8,646
    4,397
    Not necessarily. You can connect a 12 V source to the front jump point and then you can operate the rear hatch lock as per normal.
    George W likes this.
  15. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    The rear hatch proved to be a seriously minor mishap. Open rear door, engage hatch release, push up place old stick in the way, easy peasy. I am done the car started right up but once again ran out of daylight so had to wait until after work and install all the interior stuff. Cannot wait to take it for a ride. Don't know why exactly since I don't expect anything different other than a lack of the RTID. Not too bad for changing it outside in early November. Thanks to all for the help.
  16. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Hmm not what I expected, after nine miles I am getting only 24.7 mpg.
  17. dolj
    dolj Senior Member
    8,646
    4,397
    Don't worry, nine miles is nothing, heck, it won't even be fully warmed up. Come back when you have used the tank. If it is still in the 20's then you might have a problem.
  18. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Ok I am a little bit concerned though, it seemed as if though the rebuild reinstall seemed a little bit too easy to me.
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    yeah you can tell if the battery is not participating the engine will be screaming just to get on the freeway. Have to floor it to join traffic.
    It may throw a red triangle or a turtle icon on the top left corner of the mfd.
