Help Plz, I’m stranded in Van Horn, Tx
Discussion in 'Gen 3 Prius Main Forum' started by BrianStranded, Apr 26, 2021.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Sounds like the consummate National Lampoons vacation :).
    And it all worked out in the end(y).
    jerrymildred likes this.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    Apparently, the two bolts that hold the pump to the upper bracket screw in from the bottom, and the tab or protrusion that sticks out of the bracket fits into a hole in the beam of the chassis. The last bolt is installed from the top to "lock" the assembly in securely.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    This story sounds like it could be potential script for a Quintin Tarantino movie.
    Raytheeagle, Mendel Leisk and bisco like this.
  4. BrianStranded
    BrianStranded Member
    118
    84
    New Orleans, LA
    If only you knew dude, I’ll share the full story on my Prius when I’m parked...in New Orleans.
    I got the car running guys, currently in Baton Rouge, LA. Thks for the help yall
  5. BrianStranded
    118
    84
    New Orleans, LA
    I knew I should have ignored this thread until I was home free...check engine light just came on, then the “check hybrid system” then the limp mode oh muh gawwddddd. Back on the side of the road
    The inverter coolant pump is working, I suspect it is the engine water pump. I’m in Baton Rouge so I have resources here, I’m throwing in the towel and getting a tow.
  6. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Sorry to hear about your predicament. At least the engine water pump is easy to remove and install.
    BrianStranded likes this.
  7. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    A good future purchase would be a Scangauge 2, with which I continually monitor 12 volt battery voltage, engine coolant temperature, inverter coolant temperature and HV battery temperature.
    It will also detect most all Prius OBDII trouble codes.
    The price of the Scangauge is often discounted to around $120.
    After I got mine in 2012, I will never drive a car without one. It gives me good peace of mind knowing how well the Prius' systems are functioning.
  8. ETC(SS)
    7,584
    Is that better or worse than Van Horn?
    :p
  9. Mendel Leisk
    42,383
    Prayers here. (y)
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,151
    6,989
    Texas Hill Country
    You can normally see the engine coolant moving into the reservoir at the bottom port after warm up, especially if a strong led light is placed on top.
    The good news is a bad head gasket won't bring up hybrid codes or limp home mode. Unless it was so bad you have no visible coolant left. The bad news is some counterfeit pumps have been reported with short lifespans.
  11. BrianStranded
    118
    84
    New Orleans, LA
    Man o man you must be in my phone, I was just looking up odb scanners and techstream? Thx dude!
    muuuch better
    Thx
    Yeah I’m pretty sure the head gasket is blown too and I’m thinking this water pump failing help cause that. I just drove this thing 1800 miles from los Angelas, I’m gonna tear it apart once home, if I get there.
    ASRDogman and Georgina Rudkus like this.
  12. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Unknown if there is a correlation between a failing inverter coolant pump and a failing head gasket.
    Does the engine briefly rattle upon cold start up, or have you noticed a drop in the coolant level in the coolant reservoir?
    Grit likes this.
  13. BrianStranded
    118
    84
    New Orleans, LA
    Does the engine briefly rattle upon cold start up, or have you noticed a drop in the coolant level in the coolant reservoir?[/QUOTE]
    To clarify I mean the main engine water pump failing (both pumps failed) causing the head gasket to blow. And yes I’m having all those issues (rattling, etc), the inverter is fine now that I’ve changed it..
  14. BrianStranded
    118
    84
    New Orleans, LA
    It twas a fun ride, thanks guys again for helping me get home! I’ll be active here, stay tuned...
  15. ETC(SS)
    7,584
    You have California plates, a 504 AC, and your journey terminated in NOLA.
    I'm just being nosey, but are you a refugee from the left coast? :D
  16. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    His location states that he is in Van Horn, Texas. :rolleyes::eek::rolleyes:
  17. ETC(SS)
    7,584
    The picture in the last post from the OP looked closer to New Orleans than west TX....
  18. ChapmanF
    19,063
    Do you have the trouble codes yet?
    It's not like the Prius just has these two pumps and nothing else that could light those lights....
  19. fuzzy1
    10,723
    That is just where he was stranded on the day he signed up for this forum. Let's hope he updates that to a more settled location.
  20. ETC(SS)
    7,584
    Hurricane season cometh......
    The OP may want to fix the car quickly and then get back on the road!!
    Much of the area around New Orleans is now 1½ to 3 meters (4.92 to 9.84 feet) below mean sea level, according to a 2003 study by the US Geological Survey. (Jul 11, 2019) :whistle:
