Help! Prius died while driving on highway.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jadams, Nov 9, 2016.
  1. Jadams
    Jadams New Member
    Missouri
    As I was driving home from work, I began to pass the car ahead of me and once I reached 72mph I suddenly lost all acceleration and had to roll toward the shoulder. When I lost my acceleration, the dashboard was full of lights (VSC, Red triangle !, & the red car with a line through it. Once I reached the shoulder I shut the car off then tried to turn it back on. The car moved about 5mph using the battery power but then lost everything. The start button would only turn red with the lights remaining on the dash. I ended up getting the car toed home and have removed the "Electric motor" and tested each cell with none of them reading less than 7.4. I also took the 12v to be tested and it tested good. Anyone have a clue as to what's going on? 2005 with roughly 500k miles. The car has documentation for every repair/part done to the vehicle including oil changes. Ran flawless before this episode. Thanks!
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Your first mistake was not reading the diagnostic trouble codes before taking the HV pack apart.
    500K miles! Time to put it out of its misery.
  3. Jadams
    Jadams New Member
    Missouri
    The previous owner stuck in the code reader once I got it home and it read clear. Pretty senseless to put a good car out of its misery.
    primer, Dino33ca and Data Daedalus like this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It has gas, right?
  5. Jadams
    Jadams New Member
    Missouri
    Unless the meter went whacky, it had 3/10 bars which should have been plenty.
  6. jadziasman
    1,355
    488
    District 6
    The previous owner? Why are they still hanging around? How long have you been the owner of this "good car"?
  7. Jadams
    Jadams New Member
    Missouri
    I'm from a town of 2000, not everyone is out to rip someone off. I have put 30k miles on it myself. He was the second owner and put over 250k on it. Are you going anywhere with this irreverent info?
  8. jadziasman
    1,355
    488
    District 6
    I'm done here. Best of luck to you.
  9. Mendel Leisk
    42,367
    Maybe inverter failure??
    Data Daedalus likes this.
  10. Jadams
    Jadams New Member
    Missouri
    Is that common? Easy/cheap fix?
  11. bisco
    52,883
    what kine of code reader?
  12. Jadams
    Jadams New Member
    Missouri
    Not sure what brand he used. It's something he's always used on his cars. He's pretty knowledgable on cars, I am about the complete opposite, especially with the Prius.
  13. bisco
    52,883
    prius requires toyota specific reader with tech stream software. you can pick up a mini vci on amazon, or take it to a dealer.
    one thing you might check is the inverter coolant pump. open the reservoir with the car in ready and make sure there is fluid movement.
  14. bisco
    52,883
    check the engine oil level and fill it with gas as well.
    Jadams likes this.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    No. Most are due to bad jump starting or water pump failure. New $4000 Parts and labor, used about $200 for the part (warning, high voltage! use care!)
    prius inverter converter | eBay
    (2004 to 2009 should all work)
    #15 JimboPalmer, Nov 9, 2016
  16. eman08
    eman08 Active Member
    360
    192
    US
    That's a mother load of miles. Was this used as a Taxi Cab? Should have a dealer level scanner for the most comprehensive diagnostic. Tech Stream is what the dealers use for these hybrids, but are subscription based.
  17. greasemonkey007
    greasemonkey007 Active Member
    287
    107
    South Central Arkansas
    What part of MO are you in? I may be going near Branson shortly. I could bring my laptop with me.
  18. Jadams
    Jadams New Member
    Missouri
    NEMO, near Hannibal, MO. Roughly 4hrs from Branson.
  19. Jadams
    Jadams New Member
    Missouri
    He traveled to Texas weekly for work, I work on the RR. Tons of traveling for work
    Data Daedalus and bisco like this.
  20. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    Check sr 1 relay near battery ecu
