Help! Prius died while driving on highway.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jadams, Nov 9, 2016.
  1. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Obviously a lot of guessing based on experience above, but without knowing the diagnostic test codes that's all it is, guessing. It wouldn't be too wise to start replacing parts until you know for sure. If the check engine light came on (yellow, looks like the outline of an engine, my wife thinks it looks like a faucet), there are codes that will tell the story. It could also be an electrical fault in one of the two transaxle motors, who knows? You're into nearly unknown territory with that kind of mileage.
  2. greasemonkey007
    greasemonkey007 Active Member
    287
    107
    South Central Arkansas
    I work for the RR too. Glad I don't do much travelling now.
    Jadams likes this.
  3. Jadams
    Jadams New Member
    Missouri
    What is the code reader I'll need? Is it available on Amazon?
    52,883
    'mini vci' yes it is. but read the threads here to understand how it works first. this is a professional tool.
    Jadams likes this.
  5. b100
    b100 Member
    145
    75
    Netherlands
    Get the codes read,
    It sounds like a inverter failure.
    Inverter is a relatively easy fix. Buy a used one. But first get the codes read. Thats the most important thing to do.
  6. Mendel Leisk
    42,368
    The quickest way to read the codes, and one way to be sure that you're getting all the codes, is through a dealership. Just plunk down the $70~80 and get it done. You'll also get interpretation of the codes, and advice.
  7. Kate Harvest
    Kate Harvest Member
    105
    Vancouver, WA
    How's the coolant level in the inverter coolant reservoir? (The one right next to the inverter)? Is there visible movement in there when the car is on? Have you tried turning the car on again after you had it towed home? The fact that it died on you as you were revving to past is making me think maybe it's just a cooling system issue, which should be much cheaper to fix than an issue with the inverter itself.
    CatsAreGods likes this.
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Only $70 or $80?
    Around here dealers charge more near $120-$130
  9. Mendel Leisk
    42,368
    Hah, not everything's more expensive in Canada.
    bisco and Merkey like this.
  10. Kate Harvest
    Kate Harvest Member
    105
    Vancouver, WA
    $120-$130 around here too. This is why I own a mini VCI.
  11. Jadams
    Jadams New Member
    Missouri
    dealership is a no go since the car doesnt travel. Nearest dealer is 45 minutes away. im looking at readers now to hopefully figure things out. I will check the coolant level on the inverter tomorrow. thanks guys!
  12. Jadams
    Jadams New Member
    Missouri
    Now I am running into the problem that every vci is requiring windows xp where as I have windows 7. Im no techie to say the least.
  13. Mendel Leisk
    42,368
    I think win 7 works. But better wait for conformation, from someone who actually knows this stuff.
  14. Kate Harvest
    Kate Harvest Member
    105
    Vancouver, WA
    I run mine on Windows 7 under VMware Fusion under MacOS Yosemite. As I recall the driver setup under Windows was a little bit of a headache, but I haven't had to mess with it since I got it working. Google around, there should be plenty of readily available guides with links to the appropriate drivers.
    SFO likes this.
  15. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    It is more of a challenge to set up using Windowss 7.
    To save the frustration it is worth buying a $50 laptop off of Craigslist that has XP.
    #35 ericbecky, Nov 14, 2016
  16. Mendel Leisk
    42,368
  17. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Ha, ha. Yes I meant XP. Stupid autocorrect.
    I'll go back and fix it.
  18. Mendel Leisk
    42,368
    Just that I hate HP, lol.
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I guess a question I would like to ask is once you self-track down the codes, are you confident enough a DIY person that you feel you could execute repairs yourself?
    If the answer to that is no?
    Then I'm kind of in the camp that says, just don't pass go, and get it to a dealership.
    We all want to save money. But sometimes you eventually run into that dragon that won't be distracted by a piece of meat tossed in the corner. You may just have to face this dragon face on.
    Data Daedalus and Mendel Leisk like this.
  20. Mendel Leisk
    42,368
    ^ And that's where just heading to the dealership from the get go starts to look better.
    #40 Mendel Leisk, Nov 14, 2016
    Data Daedalus likes this.
