Help! Prius overheating light and losing coolant!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by preeeuss, Feb 12, 2023.
  1. ChapmanF
    19,033
    Mine has, sho 'nuff, a little rubber hat pushed over that nipple. Doesn't seal it off, just prevents it from being a straight jet of coolant if it overheats and escapes.
    I agree, I wouldn't call it a "bleeder" cap, though.
  2. Brian1954
    Brian1954 Senior Member
    2,689
    1,075
    South Central PA, USA
    I agree that "bleeder cap" is not the correct description. It is more like an overflow tube or nipple. Below is a picture that I took of my car, which shows the black rubber cap. tapatalk_1676851745284.jpeg
  3. Brian1954
    2,689
    1,075
    Did you replace your water pump yet?
    Did it fix your engine overheating problem?
