Help removing EGR valve and cooler.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 12mpg, Oct 30, 2025.
  1. 12mpg
    12mpg Junior Member
    25
    Portland
    2014 with 80,000 miles and morning rattle.
    I’m in the process of replacing the spark plugs since they’re due (12 years).
    I decided to remove my intake manifold to check/clean it and it’s really clean (compared to some videos I’ve seen online).
    I’m considering tackling the EGR valve and cooler but it looks like a pain in the butt and I haven’t found many good videos on YouTube yet that show the removal process.
    Can someone link a video they like/followed to remove the EGR valve and cooler?
    Should I even bother since the intake manifold is so clean?
    I already had two mechanics tell me the head gasket is fine but I found a mechanic who will do it for $800 so I’m about to just go ahead with that.
    Have some coolant loss + the morning rattle so I’m thinking head gasket but after a mechanic did a sniffer test and another pressurized the coolant system and checked cylinders with borescope and both mechanics told me head gasket was fine.
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,308
    5,379
    Pacific Northwest, USA
    Check out signature links in @Mendel Leisk posts... Just about everything you need to know to do that job.
    As for the pressurized test of the coolant system, do you know what pressure they went up to?
    Also how much coolant have you been losing?
    Makes me wonder if the headgasket failure between cylinder 1 & 2 at first is so slight it can only be detected when the engine gets too hot? Or if even a tiny headgasket leak when engine is running hot would show up in a pressure test when engine is cold?
    #2 PriusCamper, Oct 30, 2025
  3. Mendel Leisk
    42,124
    I'd concentrate on the head gasket first. Cleaning the EGR now is akin to rearranging deck chairs on the Titanic.
    Anyway, to facilitate EGR valve/cooler removal:
    1. Remove EGR cooler lower bracket nut/stud combo, in advance. It's fine to leave off, and can be done without removal of any other components, car is still driveable.
    2. Remove, lube and reinstall the nut/stud combo at the EGR valve, ditto for the bolt through the EGR cooler upper bracket bolt. If they're stubborn, doing this ahead of time ensures an easier main job.
    3. Before removing coolant hoses from the EGR cooler, drain 2 quarts from the radiator, into a clean container. This will drop the coolant level below the EGR components, virtually avoid spillage. Also, don't remove coolant hoses from throttle body when lifting it off for intake manifold removal: they've enough slack you can just shift the throttle body out of the way, tie to the invetter conduits. And yeah, DO remove and clean the intake manifold, paying particular attention to the small EGR passages at each port.
    4. Label everything coming off, unless it's absurdly obvious. Lay stuff out in order removed helps too.
    5. Read the top two links in my signature, lots more info, attachments with torque values, tools required. (on a phone turn it landscape to see signatures)
    Also, this workflow summary is helpful:
    Professional EGR Cleaning Resources | Page 9 | PriusChat
    12mpg likes this.
  4. PriusCamper
    13,308
    5,379
    Hey Mendel,
    If two mechanics are saying OP doesn't have a failed headgasket and there is measurable coolant loss: is it possible that a bad electric water pump causes coolant loss in a similar way as Gen2 Prius belt driven pump does? Maybe @ChapmanF knows?
    12mpg likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,816
    6,790
    Texas Hill Country
    You can have coolant loss with overheating which then relieves from the reservoir pressure cap toward the firewall. However that scenario does not explain the morning rattling.
    $800 for a head gasket job seems too cheap. The head needs to be checked and usually rebuilt by a machine shop as well, usually $500 by itself.
    The borescope check has to be done with pressurized coolant on a cold engine (typically left overnight) and it needs to be a high quality articulating (moving head) borescope.
    Car Care Nut HG Borescope at 660s
    Typical small leak
    South Main Auto
    Excellent Borescope Footage at 6:50
    Honda Misfires on Coldstart Only
    Unlikely to be this bad
    Car Care Nut Egr video with block tube test
    #5 rjparker, Oct 31, 2025
  6. Mendel Leisk
    42,124
    Look for leaks I guess, pink crusties. 3rd gen water pump failure reports here tend to be around 150k miles, and with OP having 80k, maybe not that likely. It’s early for head gasket failure too.
  7. bisco
    52,651
