Help removing stuck rear wiper arm?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobzchemist, Oct 16, 2017.
Tags:
  1. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    Unscrewed bolt, but this thing won't budge. Any way to pry it off without breaking the window?
    52,927
    would a wheel puller work?
  3. bobzchemist
    507
    342
    I don't know, but it doesn't look like it. I was hoping someone else had already run into this problem...
  4. bobzchemist
    507
    342
    WilDavis likes this.
  5. bisco
    52,927
    yes, they rent them at autocrats stores. all the best!
    have you tried soaking some wd40 overnight?
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Yup, been there, done that! (…got the T-shirt) I did it with brute force & ignorance, and just at the point where I thought the glass was going to crack :eek:, the arm popped off, and all was good! when I re-attatched the arm, I put some anti-seize on the splines to avoid the same thing happening again! To find out why I was removing the arm, you will need to look at the threads (use search) - here's a hint:
    BTW "Croil" or "Plus-Gas" can be you friend too!
    Raytheeagle likes this.
  7. bobzchemist
    507
    342
    wd-40 sounds like a good idea
  8. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    use the handle of screwdriver and tap it off
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    You've got that pic on speed dial ;).
    We us Croil all the time at work for valves:).
    Croil is the miracle oil(y).
  10. WilDavis
    2,493
    2,155
    49
    Plus-gas is what I used back in the UK, and when an old friend from Blighty visited a few (at least 20) years ago, she asked me what she could bring me (apart from herself o_O ) which I couldn't get here on this side of ThePond, and I told her I could use some Plus-Gas. It must have been an interesting experience watching her bring it through U.S. Customs! This was long before I found Kroil, and to be honest, I think Kroil to be good, but not quite as good as Plus-Gas! (…but I'm bound to say that! (of course!))
    #10 WilDavis, Oct 16, 2017
  11. alw
    alw Junior Member
    Boston MA
    There is a mechanic’s tool known as a “steering wheel puller” (or by similar names) which has claws that hook under the edges of whatever you’re trying to pull. The reaction force is directed inline with the central bolt, so no force is exerted on anything other than the stuck parts. Typically there are adjustable or interchangeable tool components to handle different sizes.
