Help request: Main Body ECU schematic?
Discussion in 'Gen 3 Prius Technical Discussion' started by Roccobro, May 11, 2024.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,963
    Texas Hill Country
    It’s hard to tell what he has done…
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    The OP's symptoms match up to a "partial" LIN bus failure. I had "the exact same problem" on a 2011 Sienna.
    Windows would function from their satellite switches, but not from the master. Kinda sorta got comm with the door modules. Codes but no data or bidirectional controls.
    In my case there was corrosion at a door connector that pulled the LIN voltage down - just a little bit. Static testing showed a few mega ohms to ground but it acted different when it was powered up (and was worse when ambient humidity went up)
    Roccobro likes this.
  3. ChapmanF
    19,019
    Funny how that can even happen. Sure enough, the diagram shows each window regulator having both a LIN connection, and direct button inputs from the local switch. Even the driver's door regulator works that way.
    But the master switch lockout button status only gets sent over LIN, so with a flaky LIN bus it might also be interesting to see if the local switches can be properly locked out from the master.
  4. Roccobro
    Roccobro Junior Member
    46
    San Bernardino, CA
    2002 Prius
    I
    No, they don't lock out from the master.
    And, the windows function with car off as well.
  5. mr_guy_mann
    4,114
    2,012
    NJ-USA
    Depends on how bad the LIN is at any given moment. On the Sienna it seemed that it would default to satellite switch function IF there was total loss of comm.
  6. Roccobro
    46
    San Bernardino, CA
    2002 Prius
    I
    Thank you for posting your experience. I'll replace the door harness and inspect the plugs for corrosion (again). I'll focus on the LIN comms wires.
    Justin
  7. ChapmanF
    19,019
    Even funnier. The diagram shows the fused circuits supplying the window regulators are all unswitched; the regulators have power all the time, and must depend on a LIN message telling them "hey, act like the car's off" when the car's off.
  8. Roccobro
    46
    San Bernardino, CA
    2002 Prius
    I
  9. mr_guy_mann
    4,114
    2,012
    NJ-USA
    Yep. The scope waveform of the LIN looked like "normal" activity. However, instead of being at almost battery voltage, the (receptive) signal voltage was a volt+ below that. Just at the lower threshold of "logic high" voltage.
    I ended up watching the LIN voltage and unplugged harness connectors until I saw the voltage go up - then followed that circuit branch until I found green death.
    I would expect the OP has something like that, a high resistance short to ground on the LIN circuit somewhere.
  10. Roccobro
    46
    San Bernardino, CA
    2002 Prius
    I
    Thank you Mr. Guy. I have slave labor to perform all week. So I ordered ANOTHER multiplex comm/fuse setup and will install with the replacement harness early next week and report back.
    My end desire it to be able to point to a common failure point for the next guy who does a Prius Chat search with the same symptoms. Minimal "give back to community" if you will.
  11. ChapmanF
    19,019
    Of course that's most useful when it turns out there is a common failure point for such symptoms, and not, say, corrosion creating a fault on the LIN bus somewhere that owners all have to find for themselves. Some issues are like that.
