HELP!!!! Rookie Mistake! INVERTOR FRIED?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pstuebs03, Feb 23, 2019.
  1. pstuebs03
    pstuebs03 New Member
    Wisconsin
    Hey everyone. Any help would be greatly appreciated.
    So I bought a used 2011 Prius. My automatic locks were not working, so I decided last night to swap out the battery. It was night time so I couldn't see exactly the positive and negative terminals. Well, I reversed them as I was trying to put the new battery in...My rear lights beeped and flashed once, saw sparks and smoke. Then I stopped there and put the old battery on correctly and tried starting the car. The dome light works as well as the headlights, but they seem dim. However, the car will not start. It shows the engine sign and then the power button just stays orange and flashes. Then I press the power button again and it shows the yellow triangle and tells me to depress the brake and press the power button. I have checked all the small fuses in the engine and under in the car and they all are fine, but the 12v battery fuse is not broken, just discolored. Could I have gotten lucky and it is not the inverter? Should I try to put in a new 12v and 12v battery fuse? How likely is it that I need to do a $3,000 repair? I just got the recall for the software from Toyota a few days ago too. Help is greatly appreciated!
    Thanks! By the way, these forums are a lifesaver! I also spelled inverter wrong. Oops.
    #1 pstuebs03, Feb 23, 2019
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,445
    3,351
    Madison, Wisconsin
    You say you have checked the fuses.
    Did you simply do a visual check, or actually use a voltmeter to check for continuity?
    Voltmeter would be best.
    #2 ericbecky, Feb 23, 2019
  3. pstuebs03
    Wisconsin
    Just a visual check to see that they were not broken.
  4. Lino
    Lino Member
    61
    38
    Hopefully you just blew a fuse, do you have a meter, what is the voltage of the old battery, if its real low put in the new one.
  5. bisco
    52,563
    ohm it out brother, you're prolyyy fine (y)
  6. pstuebs03
    Wisconsin
    Knowing Toyota would probably charge me $10,000 to get it looked at, I am going to have someone come on Monday to test the 12v battery fuse with a multi meter. Fingers crossed.
    Fingers crossed! I am fine with car repairs, just not ones that I create for stupidity. :mad:
    #6 pstuebs03, Feb 23, 2019
  7. Lino
    Lino Member
    61
    38
    Shit happens most people make mistakes some cost more than others.
