hELP: this morning my Prius (made a video 4 you 2 decide)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Odey, Feb 9, 2015.
  1. Odey
    Odey Junior Member
    San Jose, California
    Won't move in any direction...
    I made a video
  2. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Moved from the Prius v forum to the Gen II Maintenance forum.
  3. JC91006
    16,498
    8,408
    Your car is not even in Ready mode, of course it won't move. Check the 12v battery first.
    The Electric Me and Air_Boss like this.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Well you have the check engine icon illuminated.
    Why? I don't know.
    But it may clearly be time to tow for service.
  5. Odey
    Odey Junior Member
    What do you mean?..I'm doing the same things I've been doing for the past 3 years
    I took it in last year for it to have a full checkup and at that time the engine sign was on but they didn't make any issue about it.
    #5 Odey, Feb 9, 2015
  6. JC91006
    16,498
    8,408
    Cars need a battery to start it......if it dies, it won't start. You've been a member on this forum since 2013 and this topic of replacing 12v batteries before they die comes up every single day. You should just go and buy another battery. At the dealer service dept, it'll run you about $300. DIY will be around $100 less.
  7. Odey
    Odey Junior Member
    So you're saying that signal that just came up today is the 12v batteries?
  8. JC91006
    16,498
    8,408
    If I had to guess, that would be my guess. To know for certain, you need to read the car's DTC codes with a proper scanner.
  9. Odey
    Odey Junior Member
    Maybe jump starting the battery might indicate that too, right?
  10. JC91006
    16,498
    8,408
    Yes it should be able to get jump started. But just make sure you don't cross the positive an negative terminals. Make certain they are connected properly or you could do more damage to other systems that costs thousands to repair.
  11. stonerider
    stonerider Member
    107
    Lompoc, CA
    Spend $160 and 1 hour of your time and replace the 12v battery, if your 12v battery has never been replaced.
  12. bisco
    49,801
    the check engine can be set by a loose gas cap, but the car should still start.
  13. The Electric Me
    9,083
    5,798
    Poor service department that doesn't make an issue out of an illuminated check engine light. Did they reset it? Has it been off?
    Doesn't really change the parameters. You have engine warning light icons illuminated, your vehicle isn't going into ready mode. I'd start at a GOOD service department.
    Engine warning lights illuminated:=Bad
    Prius "Ready" light NOT illuminated:=Bad
  14. fuzzy1
    10,272
    Also, if jump starting from another car, don't start that other car while it is connected to the Prius. Just leave its engine off until they are disconnected.
    Jumpstarting errors have led to high four-figure repair bills. If you are uncertain or uncomfortable with doing it, then a tow to a shop is far cheaper.
  15. Odey
    Odey Junior Member
    What's interesting about this 12v battery is that I changed it last march
  16. bisco
    49,801
    ahhhh! put a volt meter on it and see what it reads, maybe you left a light on?by the by, why are you putting the fob in the slot?
  17. JC91006
    16,498
    8,408
    It may or may not be a 12v battery but when a car doesn't start, the 12v is the first suspect.
    Check the voltage on your MFD screen. While is car is "on" hold and press "display" button on the MFD screen. Then turn your headlights on and off 3 times. That will bring you to a diagnostic screen. Goto somewhere that says display or voltage check. Then you get see how your battery is doing. It's not exact but it's better than nothing. If it reads under 11.5 volts, then surely it's a dead battery.
  18. The Electric Me
    9,083
    5,798
    I've hung around Prius Chat so long, that when my toilet backs up the first thing I do is check my 12 volt.
    aaroncv3, ftl, Aaron Vitolins and 2 others like this.
  19. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    I have done the required critical google research on this issue, and it does point to a low 12v bus power. Could be a bad battery, dead battery, bad ground in the trunk, loose connections, etc. Maybe a rodent got into the car and chewed some wiring (pretty common actually).
  20. JC91006
    16,498
    8,408
    In this case, I actually believe it's his 12v
