Help? To fix or not to fix? Gen3 P3000-388, catch-22? Traction Battery too low for start?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by frankk74, Mar 2, 2020.
  1. frankk74
    frankk74 Junior Member
    2016 Prius c
    Technology
    Dealer says P3000-388 you need to replace battery ($3400 CDN) before we can diagnose any further.
    Background info:
    - READY light is on
    - Fuel (gas) is 50%
    - Prius V 2012, 243K KMs (~151K Miles)
    - Not sure about the state of the ICE
    The (catch-22) problem is that no one knows the status of the ICE?
    - And you can't start the ICE without the traction battery
    - and you can't charge the traction battery without the ICE
    The vehicle diagnostics report is attached (sorry for poor quality).
    So:
    Question 1: Does Toyota have a method to charge the Traction battery?
    (Seems the diagnostic manual nowhere mentions a charge method)
    Question 2: Do the battery blocks at 12.x-13.xV look okay?
    (When I got the car all dashboard lights were lit up like christmas, I put into drive it drove 10 feet and stopped. ICE never started. After diagnostics everything else looks normal on dash).
    Question 3: Given that it drove (10 feet) with battery and cell reports (12-13v) is it possible the traction battery is okay? But that the ICE is dead which killed (depleted) the battery?
    (When I tried to start car/engine after codes where cleared it sputtered once or twice like starved fuel or dead ICE?)
    Question 4: The diagnostic manual says address all other codes before P3000-388 is it possible they ignored them? But currently the Dash doesn't report coolant/red/yellow engine lights? (ses attached photo.) Dash-Prius-V.jpg
    Read most of the posts in here (great place thank you everyone)
    Don't have access to failure details (long story).....
    Any thoughts recommendations?
    Thanks!
    Frank
    P.S. Per:
    Is my traction battery or ecu dead? dtc p3000 | PriusChat
    (1) the traction battery might have discharged too much by "accidentally" leaving it in neutral.
    (2) your Prius "thinks" it's out of fuel for some reason - real or not.
    (3) worst case scenario- a malfunction in the HV control system involving the traction battery and/or the control system.
    #1 frankk74, Mar 2, 2020
  2. frankk74
    2016 Prius c
    Technology
    Some other people have reported success by replacing some low voltage cables? (for P3000) issues
    The vehicle has been run in a winter high road salt content area (Ontario)...
    Thx
    Frank
    51,155
    Time to move on
  4. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    It was nice knowing you.
    SFO and Rmay635703 like this.
  5. Rmay635703
    Rmay635703 Senior Member
    2,647
    1,670
    Somewhere in Wisconsin
    2013 Chevy Volt
    Put the car in D with a topped off good condition 12 v battery and cleaned up good condition cables and tow it behind another vehicle on all 4’s, if it will charge do it a good while and it might start (yes I was in a tow vehicle ahead of a Gen 1 once)
    once hv battery is filled the engine can either start or not. My guess is not and another bad head gasket failure.
    if it’s too faulted to go into drive
    you can’t do this obviously and likely can’t reset the fault long enough to get into drive.
    catch 22 but there are cheap ways of building a grid charger or buying a grid charge (if a 3rd party Prius repair guy is nearby)
    good luck
    #5 Rmay635703, Mar 2, 2020
  6. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    If HV & 12v batteries are low on charge, can you put in a fresh 12v battery and push the car down hill and Regen to charge HV battery?
  7. Rmay635703
    2,647
    1,670
    2013 Chevy Volt
    generally not, if the 12 volt is gone the game is over but on older PRII if you caught a freshly discharged HV case you could sometimes regen if you got the 12 volt working and the motor would start and race, you could proceed to clear codes after that if the HV wasn’t totally failed
    the trouble is some codes won’t allow you to even get into drive resulting in a brick.
    but it’s worth a try even if it doesn’t work often
  8. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    What I said is if you put in a fresh new 12v battery.
  9. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
  10. frankk74
    2016 Prius c
    Technology
    Thank you very much for some suggestions!
    I will try to pull out the HV cable(s) and inspect. The outside doesn't look too good?
    To answer my own question: Yes both Toyota and Lexus have HV/Traction Battery "recharge" methods (yes I know, it does not fix a bad battery).
    See: MC-10152262-9999.pdf or MC-10152247-9999.pdf (Summary: TSB: This bulletin includes basic procedures for performing a Rescue Charge on Ni-MH High Voltage)
    Both the TSBs use a Toyota specific recharging unit GRX-5100 from Midtronics (packaged in nice orange toolbox). The instructions for using them are found in the 2016 Technology updates (Toyota or Lexus).
    I'm going ask a local dealer to perform this before charging me $3400... but I'm not holding my breath.
    Using "personal" OBD(carista)+apps doesn't give any form of useful information (one app will give me the voltages of the Banks but won't give me the DTCs, another app gives me the DTCs but not the voltages....) Tried 2 OBDs and iOS and Android.
    Will provide further updates as they come in....
    Thank you!
    Frank
  11. frankk74
    2016 Prius c
    Technology
    Looks like the code P3000-388 is documented (in the prius 2010 repair manual) to put on the THS Charger and then further refined by the TSBs.... in one part of the manual (attached) but in the specific section for P3000-388 it doesn't cross reference this earlier part of the manual.
    But again not expecting much.... I'm in Canada and my guess is they haven't even heard of the charger.... (also seems to be uncommon knowledge elsewhere?)...
    Help?
    Frank
  12. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Was a known option from back in the day before we had grid chargers, and not every dealer had one.
    Not sure how much your dealer would charge for that recharging service, but you could kludge together an inexpensive LED power supply, or if money is no object, look into a grid charger at Prolong Battery Systems | Hybrid Automotive California, USA
    Sometimes you can find a used Prolong charger and or discharger here in the for sale section.
    Raytheeagle likes this.
  13. Pollymath
    Pollymath Member
    102
    37
    Flagstaff, AZ
    I keep seeing a lot of references to a DIY Grid Charger using an LED Power Supply, but I have yet to see a full walkthrough. People just kind of mention as "someone has done it, but I don't know who."
  14. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "Grid Charger" (ignore any 'LED' references...)
    For info on the product, see this.
    For a walk thru, see this.
    Comes in two variants: Less expensive; requires more user oversight and lightbulbs to determine completion of balancing. More expensive; all that is automatic. First the user must install a wiring harness on the HV battery. Look through this.
    Does NOT renew anything, per se, but rebalances all the cells so that the voltages are more equal, extending the life of the HV battery (just how much, is not exactly quantifiable, but it does work). LOTS of references on this forum. cf @Raytheeagle.
  15. Pollymath
    Pollymath Member
    102
    37
    Flagstaff, AZ
    Do It Yourself. DIY.
    As in, I don't want to pay $600, or even $350 for one of these things.
    I want to build it myself. Where's that info at?
  16. Ed Beaty
    334
    311
    Salt Lake City
    Hmmm...you must be a really-for-sure polymath then..... ;)
  17. Pollymath
    Pollymath Member
    102
    37
    Flagstaff, AZ
    Jack of all trades, master of none!
  18. Ed Beaty
    334
    311
    Salt Lake City
    Alas, there is no (that I know of; could be wrong...) set of DIY build instructions on this forum (nor any reference to such) for an HV battery grid charger. The DIY aspect of the Prolong system: buy it, install the harness, then operate it yourself...
    It DOES get high marks from forum members that have used it, and even the expensive automative version is WAY cheaper than a new HV pack.
    Better start working on that electrical engineering degree.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    There are plenty of folks using hobby chargers and reconditioning individual modules themselves;).
    Look in the gen2 section and you'll see a very long thread about individual module replacements which discusses hobby charging:).
    Those solutions are a longer time commitment which is why the Prolong Equipment makes sense. So while more monetary investment, you get that back in time (y).
  20. Pollymath
    Pollymath Member
    102
    37
    Flagstaff, AZ
    Thanks Ray.
    I've connected with a fellow Northern Arizona resident who's got a Prolong and we're going to work together so I can rent it from him.
