Help to identify connector (behind front bumper)
Discussion in 'Gen 2 Prius Main Forum' started by Victorio Mo, Jul 5, 2019.
Tags:
  1. Victorio Mo
    Victorio Mo Member
    147
    36
    Folsom, California
    Hi All,
    I just replaced front bumper cover and find some loose / disconnected connector like on photo, it's located on the center , behind metal bumper , I have fog lights and they working OK.
    Is this for AirBag ?? I posted photo. Small piece is also loos with yellow insert. Thanks for help !!!
    https://i.stack.imgur.com/BoePz.jpg
    Best mario
      File size:
      31.7 KB
    #1 Victorio Mo, Jul 5, 2019
  2. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    Outside temperature sensor?
    Raytheeagle likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    If its high on center its either the horn or the temp sensor. See if horn works or the outside temp on the mfd works.
  4. Victorio Mo
    Victorio Mo Member
    147
    36
    Folsom, California
    Tx all !!
    Horn works OK. So Temp Sensor is solid candidate. Still need to figure out do I need to plug anything between those 2 or not. There 2 pieces and big one has kinda of latch. on top left photo I hold 2 of them. They both on 2 wires.
    Anybody knows where this sensor attached ?
    Best
    #4 Victorio Mo, Jul 5, 2019
  5. Fixnstuff
    Fixnstuff New Member
    Brampton Ontario Canada
    Second picture looks like outside air temperature sensor. It should be attached to the one metal bar running up/down between the front bumper and the ac condenser/rad. Third picture looks like the connector that plugs into the hood latch which has a switch to trigger the burglar alarm if someone opens the hood with alarm on (doors locked). Good luck!
    Victorio Mo likes this.
