Help! VVT solenoid handle broke off while removing it!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wbs887700, May 3, 2022.
  1. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    JahT likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,446
    5,428
    Pacific Northwest, USA
    Got a valid reference for that claim?
  3. wbs887700
    wbs887700 Junior Member
    74
    Is this where the oil screen is?
    JahT likes this.
  4. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Looks about right.
    #24 alftoy, May 4, 2022
    JahT likes this.
  5. PriusCamper
    13,446
    5,428
    Has anyone ever pulled a screen with debris in it? Seem kinda unlikely unless engine oil filter bypass is engaged from it being not replaced after each oil change/clogged up?
    JahT likes this.
  6. alftoy
    1,132
    519
    JahT likes this.
  7. James Analytic
    411
    63
    Michigan
    You had a post elsewhere noting an 8mm hex key and I forget maybe with a 3" extension. Finally got around today to removing one at the yard to see what the experience is like. As usually, wondering what the interchange is and found Toyota 15678-21010 Filter, Oil Control Valve is used in the following:
    Vehicle Fitment
    Year Make Model Trim & Engine Important vehicle option details
    2004-2006 Scion xA 4 Cyl 1.5L 1NZFE; NCP61L-HHMNKA, NCP61L-HHPNKA
    2004-2006 Scion xB 4 Cyl 1.5L 1NZFE; NCP31L-DHMNKA, NCP31L-DHPNKA
    2010-2012 Toyota 4Runner 4 Cyl 2.7L, 6 Cyl 4.0L 1GRFE, 2TRFE;
    2000-2005 Toyota Celica 4 Cyl 1.8L 1ZZFE, 2ZZGE;
    1999-2008 Toyota Corolla CE, LE, S, STD, VE, XR, XRS|4 Cyl 1.8L 1ZZFE, 2ZZGE;
    2000-2005 Toyota Echo 4 Cyl 1.5L 1NZFE;
    2000-2005 Toyota MR2 Spyder 4 Cyl 1.8L 1ZZFE;
    2003-2008 Toyota Matrix CE, LE, S, STD, XR, XRS|4 Cyl 1.8L 1ZZFE, 2ZZGE;
    2001-2009 Toyota Prius 4 Cyl 1.5L 1NZFXE;
    2012-2019 Toyota Prius C G, R, V|4 Cyl 1.5L 1NZFXE;
    2005-2023 Toyota Tacoma Base, Limited, SR5|4 Cyl 2.7L, 6 Cyl 3.5L, 6 Cyl 4.0L 1GRFE, 2GRFKS, 2TRFE;
    2006-2018 Toyota Yaris RS, STD|4 Cyl 1.5L 1NZFE;
    For reference in regards to the VVTi Timing Solenoid Toyota 15330-21011 Valve Assy, Camshaft Timing Oil Control:
    Vehicle Fitment
    Interestingly, the Prius C uses a Toyota 15330-21030 Valve Assembly, Cam Timing Oil Control:
    Vehicle Fitment
    Wondering what the differences are between the Prius C and gen 2 Prius VVTi Solenoids?
