Help what is leaking?
Discussion in 'Gen 2 Prius Main Forum' started by amjohnson, Mar 18, 2018.
  1. amjohnson
    amjohnson Junior Member
    77
    US
    I changed my oil on my 2008 Toyota Prius it is wet in the area that I circled and red it can you please help me and tell me what is it leaking from this area there is a black plastic Square there. Capture%2B_2018-03-18-15-41-34.jpg Capture%2B_2018-03-18-15-44-36.jpg
    52,782
    any drips on the ground, or low fluids?
  3. amjohnson
    77
    US
    Not that I can tell.
  4. DMC-5180
    DMC-5180 Active Member
    294
    134
    If its red oil, its most likely transmission fluid seeping from the input shaft seal. Minor drip or just a trace on the case is nothing to worry about. If you leave noticeable evidence on the ground after you park, then it would be of greater concern and you should have the level checked and topped when you do your oil changes.
    iPhone X ?
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Or maybe have the seal repaired so you are not dogged with this for the rest of you and your cars time together!
  6. bisco
    52,782
    crack the fill plug and see if anything comes out. if not, stick a finger in. if you can't touch it, add until it start to come out. measure how much you added.
    if it isn't dripping on the ground where you park overnight, it likely isn't a major issue.
    amjohnson likes this.
