Help, what is the trick to setting cruise control?
Discussion in 'Prime Main Forum (2017-2022)' started by Tesla1st, Jan 3, 2017.
  1. Tesla1st
    Tesla1st New Member
    Lafayette Ca
    I have had other Toyota's before with dynamic cruise control, but it seems to be hit or miss when I try to set to darn thing. I know there is two types and to switch you hold the on button longer, and push down to set speed but it will not hold speed. Anyone have a video on how to engage?
  2. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    You seem to have the basic operations, so perhaps it is slowing down to open up the distance between your car and the car in front? Perhaps the car in front is traveling slower than the set speed? Does the dashboard indicator show the cruise control on and speed set?
  3. Tesla1st
    Tesla1st New Member
    Lafayette Ca
    Even with no car in front of it, the cruise has been finicky.
  4. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    minimal set speed = ~28mph
    manually adjust speed as traffic condition changes
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I find myself having issues with cruise control. If I have it set for, let's say 35 MPH then the speed limit changes to 40 or 45 MPH I try to set it to the faster speed only to find out you have to disengage cruise at the previous speed (35 MPH) then reengage at the faster speed or the car will simply slow down to the 35 MPH speed instead of cruising at 40 or 45 MPH.
  6. TinyTim
    TinyTim Active Member
    418
    243
    Seattle
    Mine works perfect. Set your radar cruise by hitting the radar cruise over and over until you get setting 1,2,3. When setting your cruise the on dash display shows what MPH you have (set at) selected. Toggle up or down on the cruise control lever and your speed shows what you are set at and either increasing to or decreasing.
  7. TinyTim
    418
    243
    Seattle
    If you are driving with cruise control at those low speeds, set your radar cruise to setting 1 which is the closest following distance to the car in front of you. I think that is why your car is slowing down. With regards to changing speeds of your cruise, you can do that on the fly by toggling up either holding it up or click by click.
  8. Jerbear949
    Jerbear949 Member
    61
    42
    Ladera Ranch, CA
    Exact same way i use it... have had zero issues so far... although i was nervous the first time i was in traffic and told myself to keep my foot off the pedals... lol!
  9. TinyTim
    418
    243
    Seattle
    Something else I would like to point out regarding radar cruise. I was following several vehicles on the freeway @ 60+MPH two cars slowed down to about 35 MPH in front of me and my radar cruise slowed me down to the same speed while keeping a safe following distance and speeding up to my pre-adjusted cruise control speed of 64MPH. If you are a bit worried/paranoid about the radar cruise working well. Set your radar cruise to setting 2 or 3. It's not quite self driving but sometimes it feels like it.
    It's one of the features that sold me on a 2017 over a 2016 Prius.
    priuscatprimeguy likes this.
  10. CaliforniaPrius
    313
    201
    Alameda, California
    What makes prime DRCC shy of tesla's TACC is that it looks to me my prime can't tell the general traffic condition other than the car right in front of mine. Sometimes when other cars at adjacent lane slow down and as a human, I know something's going on ahead. Usually I'll slow down however my prime still cruises on until the car in front of me slams its brake. Then I'll get a huge BRAKE sign at the central panel.
    Since2002 likes this.
  11. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Agree, on all points, it's a bit different. But , I like the automatic braking.
  12. Andyprius1
    2,327
    859
    Cool CA
    You are in charge, Cx AB and Cruise to a stop, after all, there is only one intelligent being and it's not the AB SYSTEM.
  13. priuscatprimeguy
    2,730
    2,640
    That's not what I was saying,the radar cruise works fine for me, what I was saying speed limits change while traveling so I find myself adjusting the cruise control to keep up with the increased speed, I don't use the lever up to increase speed (but that's just my preference)
  14. Andyprius1
    2,327
    859
    Cool CA
    The Problem in that case seems to be CC NEEDS TO RESET again, or drive manually.. Talking to it and cursing it helps a lot too.
  15. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    I had my first experience with DRCC a month ago in a rental car when I got a free upgrade to an Infiniti. While it was flawless following a car already in front of me, a couple of times a slower moving car in the next lane pulled in front of me and DRCC did not handle it correctly. Even though I could see the car moving into my lane, the CC apparently couldn't, because it maintained the same speed until the offending car was directly in front of me, but by then I was practically on top of it. I learned that the moment that you see or even anticipate that a car is about to move into your lane and that clearance may be tight to cancel the cruise and start slowing down, then resume only after they are in front of you.
  16. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    Tesla1st, could it be that you may be driving in "B" instead of "D" shift position? Either cruse control will not engage in "B" position even when your cruse control is turned on.
  17. TinyTim
    418
    243
    Seattle
    Self driving cars are a cool concept. Until they start killing people in accidents. I think the TSS system is done correctly. It's as if some people want the cars to drive for them so they can correct them if they make mistakes and applaud them for a job well done. Whatever happened to the idea of simply driving?
  18. Tesla1st
    Tesla1st New Member
    Lafayette Ca
    Heiwa, hit the nail on the head I was always in "B" mode while trying cruise control. This is why I posted the question in the first place, I figured someone already figured this out, thanks. You would think Toyota would have a indicator screen advising "option not while in Battery Mode".
  19. Pizza Driver
    158
    156
    United States
    B is not battery mode. It is braking mode for use on steep downgrades. It is essentially low gear for a continuously variable transmission. In general you should not be using the B mode except on long, steep down grades.
  20. Tesla1st
    Tesla1st New Member
    Lafayette Ca
    Well that explains alot I'm stupid, for not reading the manual.
    Andyprius1 likes this.
