Help, window hitting door guide.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EkS, Aug 9, 2015.
  1. EkS
    EkS Junior Member
    s. cali
    I've got a 2005, and when I roll the window down it would make a noise. So today I take the door panel off and I discover that the door guide hits the window.
    Anyone know what the actual piece is called or a part number? Anyone have experience removing and replacing the piece?
    #1 EkS, Aug 9, 2015
    52,863
    no, but doesn't it just bolt on from the outside?
  3. EkS
    EkS Junior Member
    s. cali
    Yes it does only bolt on from the outside. Just want to make sure there isn't more to it than the 3 bolts. But I also need the part number for the driver's side guide.
  4. ChapmanF
    19,038
    Metro Toyota Parts Now or Village Toyota Parts are good online sources for part numbers and ordering. Goes without saying, techinfo.toyota.com is best for R&R instructions and tech information.
    -Chap
