Help with ABS and yellow ((!)) light
Discussion in 'Gen 2 Prius Main Forum' started by Brando714, Aug 26, 2020.
  1. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    These 2 lights just came on this week and has been on ever since. My MPG went from 40.5 to 36mpg. I hope it's not the brake actuator but please tell me your experience or knowledge on these yellow lights and how much is the part and any links on how to fix it. Thanks
  2. DMC-5180
    DMC-5180 Active Member
    294
    134
    Vehicle mileage? When was the last time you did a brake job on it?
  3. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    I have about 180k on it and when I got the front tired replaced, I was told I still have abput 65% and as for the back, not too sure since the vrake pads arent exlosed but rather covered
  4. DMC-5180
    294
    134
    Rear Disc or Drum Brakes?
    Have you checked your brake fluid level?
    You really need to have the codes checked. Any auto parts store will usually read the codes for free. ABS codes cannot be cleared with a basic code reader. But the auto parts stores usually use the higher end units with that capability.
    Also look for wet fluid on the inside of the tires after it has sat overnight.
  5. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    Ya brake fluids are good. My bluetooth obd2 scanner didn't detect anything but I will try the plug in tomorrow, thanks
  6. bisco
    52,750
    rear on a gen 2 are drum in n/a
    SFO likes this.
  7. bisco
    52,750
    jack her up and spin the wheels to see if anything is binding. alternatively, after a long drive, feel each wheel to see if one is hotter.
    also, press and release the emergency brake a few times, maybe it is dragging. you can try getting her up to 30 mph and hitting neutral to see if she glides well.
  8. DMC-5180
    294
    134
    I thought they offered rear disc as premium package upgrade on the later gen 2’s
  9. bisco
    52,750
    hmm, could be? doesn't ring a bell
  10. ChapmanF
    18,939
    two days nine posts still no codes
  11. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    Ya I noticed on the freeway that when I release the gas pedal, it does decelerate more rapidly than usual.
