Help with AC fix
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Seth Church, Jul 16, 2019.
  1. Seth Church
    Seth Church New Member
    Durham, NC
    Hi everyone, just acquired myself a 2008 prius for a fantastic deal. Owner said the AC had just recently gone out and i am setting out to fix it. Here's where I'm at so far-
    - Checked the low pressure line, nothing came out. Filled up to about 30psi. AC worked for about a day and then has been blowing hot air since.
    - used a nicer AC gauge from Oreilly and found the low to be at around 10psi and the high to be at 0.
    - added some more freon, nothing changed.
    - used the auto/recycle button combo to find the error codes and got codes 31 and 33. The common denominator between these two is the ac amplifier which i have looked at but dont know how to tell if its working.
    The air blows continually at a warm (not hot) pace but will not get cool. Can someone help me out here? Trying to fix this by myself but don't really know where to start. Looking at the repair manual ill copy what the other possible issues may be. Thank you in advanced!
    error code 31-
    Air mix control servo motor (air mix damper position sensor)
    - Wire harness between air mix control servo motor and air conditioning amplifier
    - Air conditioning amplifier
    error code 33
    Air outlet control servo motor (air outlet damper position sensor)
    - Wire harness between air outlet control servo motor and air conditioning amplifier
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Hopefully you checked around here first and didn’t fill the system with Freon with regular PAG oil in it. The fact it worked for a day and then didn’t usually means you have a leak somewhere, and a big one at that. Unless you used Freon with PAG oil in it. If you did that you may have caused damage to the cooling system.
  3. ChapmanF
    18,947
    Your trouble codes indicate issues with the air mix and air outlet servos. You are lucky to have a Gen 2, where of the three HVAC servos, those two are both on the easy-to-reach side of the unit. One of them has a screw with difficult access behind another module that's in the way, but yitznewton found a tidy way around that.
    Those issues are separate from whatever is going on with your refrigerant possibly leaking; I don't know what's up with that. If the car were mine, I think I would have started by troubleshooting the reported issues first, before anything to do with the refrigerant charge.
  4. Skibob
    2,912
    1,505
    Northern California
    I differ in I would fix the leak first. Who cares about the doors if you are losing 20psi of Freon in a day. Plus if the evaporator is the part that’s leaking the dashboard has to come out anyway.
    Edit: he does say he added more Freon and nothing happened. So I guess I would check the servos first then. :whistle:
    edthefox5 likes this.
  5. ChapmanF
    18,947
    The "losing 20 psi of Freon in a day" is not something you can say by just looking, but only after choosing to frob with the refrigerant charge for some reason in the first place. The information available at the outset was only what problems the car was actually reporting, and that's where I would have started.
    My comment was about the outset ("would have started"). If we're here now and the OP is sure, based on messing with the charge, that it is leaking, then yes, the leak should be found and fixed. I wasn't there to see the tools or techniques or what exactly happened, so there's more than one possibility I can't rule out from where I'm sitting. When a person decides to start poking at the schrader valves on the sealed system, sometimes part of what happens next may be self-inflicted. From here, I can't say.
    That's the main reason at the outset I would have begun with what the car was reporting. It's an obvious place to start, without creating possible complications when they can be avoided.
    Skibob likes this.
  6. Seth Church
    Durham, NC
    Appreciate the help everyone-
    So two things that may be of value-
    1) I definitely did put freon that contained PAG oil into the car. Good news (hopefully?) is that i havent really run the AC much so it may not have gotten to damaging the compressor yet. Question: would i be getting different error codes if the oil was causing the problem? Looking up different websites it seems like the oil can cause the air flow to be warm all the time like I am describing.
    2) regarding the leak- I used a "cheaper" gauge (came with Supertech refrigerant) which said that my psi was 30ish when i originally filled it up. When i used the actual nicer gauges from O'reilly, thats when I got the 5ish psi. When i tried adding a little bit more freon after going to Oreilly, the gauge on my cheaper Supertech refrigerant said 30-40ish psi. So dont know if i actually lost that much freon or if one gauge is wrong or what.... what do you guys think?
    Also read on one forum that the AC line can hold up to 16oz of freon- the can i bought holds 16oz and I'd guess it's still half full? So maybe I just bought a really crappy bottle of refrigerant with a broken gauge and could try a good one? (Keeping in mind that my low port was completely empty before adding anything)
    #6 Seth Church, Jul 17, 2019
  7. Seth Church
    Durham, NC
    And just to clairfy, I am about 2 weeks into learning everything about AC... so I thought warm air typically meant low freon before I even knew you could find the error codes on the prius. Only after adding a bit of freon have i been digging into the forums and found out about the error codes and am now posting....
  8. Skibob
    2,912
    1,505
    Northern California
    Don’t even try to run the system again until it’s cleaned out by a superior cleaning system. Like a hecat. I can’t say if the compressor is damaged but you made a mistake.
    People make mistakes, it’s human. Don’t fault yourself, just move forward. Sometimes a mistake is the best way to learn
  9. Patrick Wong
    18,210
    6,517
    1. The capacity of the system is 15.9 ounces of R-134a +/- 1.1 ounce.
    2. The use of compressor oil other than ND-OIL11 was a serious mistake.
    3. The factory repair manual advises that it is necessary to replace the evaporator, condenser and compressor if the wrong oil is introduced. If this is not done, a high voltage ground fault may result.
    4. It will be very difficult to replace the evaporator as almost all of the instrument panel assembly must be removed for access.
    5. After this is done, it will be necessary to use a vacuum pump to evacuate the system, then introduce pure R-134a into the system.
    6. If a vacuum cannot be maintained, then some other part is leaking.
    7. Get the factory repair manual info at techinfo.toyota.com and plan to spend lots of $$$ and labor effort to make this right.
  10. ChapmanF
    18,947
    There was an article (not sure exactly where at the moment, but I linked to it in another PriusChat thread some time in the last mumble months), suggesting a shop with a HECAT flushing rig (that type, specifically) might be able to flush everything adequately, if applied soon enough after the wrong oil entering the system. It wouldn't be a Toyota-approved replace-everything-in-sight fix, but it wouldn't be a Toyota-priced one either.
    My main anxiety would be about the if applied soon enough part; if I remember right, the article's authors were thinking of a quick "yikes! I put in the wrong oil" scenario, not one of it sitting in there for some days or longer.
    Skibob likes this.
  11. Skibob
    2,912
    1,505
    Northern California
    At this point I would think the hecat flush would be the cheaper option. What’s the worst that could happen, it fails and you replace those parts anyway?
  12. lech auto air conditionin
    830
    606
    261
    san francisco
    Unfortunately you cannot use a flush kit well the expansion valve or orifice tube are in the system when the expansion valve or orifice tube are easy to get under the hood and only take 15 to 30 minutes to replace you bypass tube them with a solid open tube unfortunately in most older Prius the expansion valve is under the dash located with the evaporate tour. PAG Oil does not cause immediate damage it’s a long term problem over time . Just like leaving moisture or air in the refrigerant system does not cause immediate damage it’s a ticking time bomb that causes failures later on .
  13. lech auto air conditionin
    830
    606
    261
    san francisco
    The most important thing is to try to diagnose an air-conditioning problem with a correct charge of refrigerant this is not something that you guess at and you do not determine the charge of air conditioning by using pressure it is done by weight only. 1: you completely recover all existing refrigerant out of the system. 2: You put a vacuum pump on until you achieved roughly 500 µm or below deep vacuum. 3: Then you fill the refrigerant by weight only determined by the under hood sticker that is usually yellow on a Prius depending on the Prius can be anywhere from 420 g to 580 grams you have to follow the sticker under your hood different years and models have different weight capacities of refrigerant.
    4: now we have to deal with finding your leak hopefully you or somebody else has installed a good quality UV trace dye but this is only finding very big leaks or leaks that happen over a long period of time and if the leak is in a place that you cannot see with your eyes it will do no good. 5: this is where a skilled technician with experience and a high-quality professional grade electronica refrigerant leak detector preferably one that the factory provided a calibration bottle so the leak detector can be periodically calibrated to prove its accuracy and sensitivity. In the automotive technical field this is where are you weed out the men from the mice most shops or technicians are too cheap or uneducated to buy the better leak detectors to actually to perform a quality job. After filling the vehicle with refrigerant the technician will go over the entire system to try to pinpoint the leak. On the Prius the condenser is the number one culprit for your first place to look for a leak. When the Prius gets a little older with some age and mileage the evaporator is the second most common leak. 6: most importantly keep people away from O’Reilly and other auto parts stores that sell those big cans with a little funky gauges attached to them that are highly in accurate with other chemicals mixed with the refrigerant other oils with leak sealer‘s and a special super lube synthetic extra cool additives these do it yourself cans are poison to the electric compressor on a Prius. It sometimes may work out first and the customer is really happy that they got cold air but after one or two or more times a fill up with the snake oil the owner of the car ends up buying a burnt out compressor then the condenser Hass to be replaced all the lines need to be flushed the expansion valve needs to be replaced just because of good advertisement to purchase Snake oil cans. Just like the phrase ( Friends don’t let friends drive drunk ) in this case ( Friends don’t let friends buy cans of refrigerant from O’Reillys ) lol
