Help with brake issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dpframing, Aug 29, 2017.
  1. dpframing
    dpframing "Nobody tells me what to do, not even me."
    78
    Chester NY 10918
    2022 Prius Prime
    I have a 2013 Prius 2. I took it in to get inspected, and the guy calls me and tells me it' gonna fail inspection because the front pads are low. So I gave him the ok to replace the front pads. 15 minutes later, I remembered that I did NOT tell him to disconnect the hybrid battery. The job was half done by then. I call him and he says to me that he's done plenty of Prius brake jobs without the disconnect, and it never was a problem. I drove the car for 15 minutes after I picked it up, and it ran fine- no lights , codes, etc. and it was braking and charging normally. Of course I looked at the pads he replaced, and there was AT LEAST 1/4" of meat left on them. He claims the computer failed them. Anyway, should I expect future problems with the car because of any of this?
    Thanks for reading.
    Domenic
  2. gliderman
    gliderman Active Member
    751
    225
    I have done brake work on mine twice without disconnecting the battery. First time to change pads and replace fluid. Second time to grease the caliper pins.
    In Texas the computer cannot check the thickness of the brake pads. I dont know how any computer could. So I call BS on that one. Never go off what a inspector says is wrong. Have him show you. Then take it somewhere else to get it fixed.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Never heard of a computer failing a brake inspection by the thickness of the pads. If your pads are less than 1mm, you will hear the metal brake indicator rubbing on the rotors. The minimum thickness to replace the pads are 2mm. You can also watch out video to learn how to replace your brake pads and rotors too :)
    Also, you don't have to disconnect the battery, just make sure not to open any doors while working on your brakes.
    Grit likes this.
    52,854
    amazing he gave you the incriminating evidence back. maybe he's just dumber than crooked.
    Grit likes this.
  5. dpframing
    78
    Chester NY 10918
    2022 Prius Prime
    I imagine I lucked out and the doors stayed closed when he lifted it up.
  6. Mendel Leisk
    42,345
    I'm sure you're right, guess I just REALLY want to be sure.
    Maybe, hopefully, it's only the driver's door that matters. I'm thinking it's a good idea to sneak into the car via passenger door, reach down and hand-tromp the brake pedal, to for sure take up any excess travel? Especially if you've pushed the pistons back for new pads.
  7. NutzAboutBolts
    1,756
    1,789
    Bay Area
    well, once the brakes are replaced and put back, opening the driver door shouldn't be an issue to go in the driver side and pump the brakes. Why pump the brakes while still working on the brakes?
    JC91006 likes this.
  8. JC91006
    16,936
    8,647
    I think edthefox had a write up about doing brakes and not disconnecting the 12v. He would put blue tape on the drivers door handle to remind him not to open the door
  9. Mendel Leisk
    42,345
    I always think, when everything's done, and before hooking up 12 volt, or turning on car, pump the brakes, remove excess travel. I heard somewhere the computer can detect excess travel, throw a code. Haven't had it happen though.
  10. Mendel Leisk
    42,345
    I think that was @NutzAboutBolts , the blue tape, IIRC, lol.
    Man, posting is like spreading pelletized fertilizer in a hail storm right now...
    Raytheeagle likes this.
  11. JC91006
    16,936
    8,647
    Lol oops. Yeah, just don't want the brakes activated when you're working on them. Perfectly fine once it's put back together
  12. NutzAboutBolts
    1,756
    1,789
    Bay Area
    well if the engine is off, the ecu can't detect if the brakes are activated or not... Hope that makes sense? lol
