help with codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tim Edwards, Jul 11, 2018.
  1. Tim Edwards
    Tim Edwards New Member
    Monroe IA
    I have a 07 pruis replaced HV battery last year and all was good but the lights came back on had it ran and the codes poao8dc/dc . p3000,P0A80,p3014, and they said I need a new HV battery . So I called the place and the sent a a new one put in last night stated to work this morning and the light came back on . I chacked inverter pump it was running .
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    P0A80. Replace hybrid pack
    P3000. Battery ecu
    Po3014. Battery pack 4 weak
    Make sure orange interlock is properly locked. Push it in flip up handle and then slide handle down till it locks.
    Disconnect 12 volt battery to remove stored codes, make car ready hit ready button once all test lights come on hit ready button again to shut off then hit ready button once more and it should make it ready.
    Who is the “place”?
    Tim Edwards and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    In addition to what @edthefox5 said above, I have some questions:
    • Is this a new Toyota battery or a battery from another source?
    • What type of warranty are they offering?
    • How many miles on your Prius?
    • Do you still have the old pack that failed?
    • Do you have a way to read the codes and if so, what type of device are you using?
    Good luck and keep us posted (y).
    Tim Edwards likes this.
  4. Tim Edwards
    Monroe IA
    Best Hybrid Batteries out of shorewood IL
  5. Tim Edwards
    Monroe IA
    no it was a rebult from best hybrid batteries . got a 3 year warranty , 186 000 ,yes, no I had pella car car read the codes and they said I need a new battery
    best hybrid batteries out of shorewood IL
    #5 Tim Edwards, Jul 12, 2018
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Since it’s a rebuilt battery, all bets are off other than it will fail;).
    It lasted a good bit, but this will be familiar territory :(.
  7. JC91006
    16,936
    8,647
    How did they send the battery and didn't install? They need the old battery back? Most of these services have mobile installation.
    Read the codes again, you might have gotten a bad battery. This will be a rough 3 years for you
    Raytheeagle likes this.
  8. Tim Edwards
    Monroe IA
    Here are the codes after replaceing battery b1821,b1826,b1653, b1655,c1259,c1310and p3011 holey shit . thats the HV battery
    SFO likes this.
  9. Tim Edwards
    Monroe IA
    I fixed the frount seat it got unplaged
    SFO and Raytheeagle like this.
