Help with connection for Rostra Cruise Control
Discussion in 'Prius c Accessories and Modifications' started by mdooley, Jul 16, 2013.
  1. mdooley
    mdooley Junior Member
    Arizona/California
    We bought the Rostra Cruise Control for our new Package 1 after seeing success on the forum and good reviews on Amazon. However, when we went to connect the ECM Harness to the ECM, the tabs would not press in and push up the terminal retainer, so we were unable to get the wire properly connected. Now there are holes in the tabs that you were supposed to press in.
    At one point, we thought we had the wire connected, but it did not work.
    Suggestions? Should we try to drill through the terminal retainer to get the wire in and try to secure it well? Should be replace the entire G58 connector? Other ideas?
    Thanks,
    Ming
