Help with diagnostic
Discussion in 'Gen 2 Prius Technical Discussion' started by Prius Plz, May 14, 2017.
  1. Prius Plz
    Prius Plz New Member
    Warner Robins GA
    this is my first time using this forum.
    So yesterday I went to get an oil change. They also did an alignment check because one of the tires was wearing a little funny.
    Anyhow after I left I had 3 lights pop up, Check Engine/Red Triangle/ and (!) which is breaks I believe probably ABS. Also my car will not display any of the hybrid technology on the screen it just has a car symbol with a line through it.
    I thought it was just that my 12v battery had finally given out. It has been having trouble staying charged overnight so I exchanged it and installed my new one but the errors did not go away. I had them reset the errors at the auto store but they came back on shortly after driving and still no display on the screen.
    I believe when they did the alignment check and hooking up those sensors to my tires they may have damaged the wheel speed sensor and or the wiring for it. What do you think the likelihood of this being the cause?
    I have a new job and need to travel 400 miles for training tomorrow how dangerous would it be for me to operate this vehicle?
  2. JC91006
    16,480
    8,397
    What's the year and mileage of your car? Can you get the codes read?
    Is there too much oil in the car? That always can cause problems if it was overfilled
    Raytheeagle likes this.
  3. Prius Plz
    Warner Robins GA
    I checked the dip stick and it did not appear to be overfilled.
    The car has 176,000 miles on it. I had the codes read before I replaced the 12v battery and they were giving me:
    P3017 battery block 7 becomes weak.
    P0A80 Replace Hybrid battery pack
    I know the hybrid battery was replaced around 100k miles from the carfax I received with the vehicle. Also I know if the 12v battery is bad it can give some weird codes, the 12v was definitely bad it was leaking battery acid.
  4. JC91006
    16,480
    8,397
    Oh you have a bad hybrid battery. The 100k miles battery change was probably the 12v battery.
    I don't think you should travel 400 miles on the bad battery. Although if it's all highway driving, you might be able to make it ok but your acceleration should be greatly affected
    The 12v should not be leaking, it's a sealed unit. If there's moisture around the 12v, it should be water leaking in
  5. Prius Plz
    Warner Robins GA
    I ran the self test and the 12v was only reading around 11.6 volts. From what I understand anything below 12 is no bueno. Also the hybrid battery inside the car is not OEM so it was definitely replaced at some point.
  6. JC91006
    16,480
    8,397
    You can charge the 12v back up and see how well it holds. Usually batteries under 5 years old should still be ok.
    Your big problem is the failed HV battery. That is the main failure
    pashko90 likes this.
  7. bisco
    49,432
    a non oem hybrid battery (rebuilt) is iffy at best. you were fortunate to get 76k out of it.
  8. Prius Plz
    Warner Robins GA
    I will rent a car for this trip and hopefully when I return home I can get it in to Toyota and they can give me a proper diagnosis. I hope you guys are wrong about it being the hybrid battery but you are probably right.
    Mendel Leisk and bisco like this.
  9. bisco
    49,432
    i hope we are wrong also. all the best!(y)
  10. JC91006
    16,480
    8,397
    You have a proper diagnostic, the Prius ECU telling you the code as P0A80
  11. pashko90
    pashko90 Junior Member
    47
    28
    SoCal
    I have no clue about all US, but rebuild HV batt pack runs roughly 500$ craigslist price.
  12. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    360
    A penny wise and a pound foolish.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    But your not. It clearly even states what block is bad in the hybrid battery. Not sure why the op is going to spend $100 at the dealer to have them tell him what is plain to see.
    Almost every other post we see here now is a bad hybrid battery on a G2. This site desperately needs a HYBRID BATTERY forum. We can list all known battery vendors and repairers. Stickies on diagnosis and diy battery repair. Links to parts. List of Craigslist guys who mostly should be avoided as most are fly by night whack a mole repairs. Review them and grade them and a watch out list for Craigslist battery bandits. Alot of people are getting screwed over by the Craigslist battery bandits.
    Battery repair can advertise on this site linked to that forum. Posters are coming here in droves for that specific help and all they can do now is read hundreds of old posts for info. This site could do a better job harvesting them. Or sooner or later another site will.
    bisco, Raytheeagle and JC91006 like this.
  14. pashko90
    47
    28
    SoCal
    Yes, i did not order any CL repairs, i did trust only myself all my cars) Even more, you can buy used pack as-is for 350. As parts or as good pack. It deepens how lucky are you. Or rebuild for 1-2k, but i did buy usally whole car for this price))))
