Help with dreaded p0aa6 code
Discussion in 'Gen 2 Prius Technical Discussion' started by OmaramO, Sep 26, 2018.
  1. bisco
    52,694
    Isn’t that too tight?
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    By 2 inch pounds ;).
    Which ain’t much:cool:.
    But good attention to detail(y).
    52,694
  4. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I bet he’d torque up to 48 inch pounds too:).
    3 passes to the target is the goal(y).
  5. Kiwibird
    Kiwibird Junior Member
    56
    Sydney
    i-Tech
    Did I end up fixing the problem, what was wrong? I am having same code but car drives completely fine...
  6. Bigbob22
    Bigbob22 New Member
    santa rosa, california
    Same I have same burnt lug.. .waht is the deal?
    Tbkilb01 likes this.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Burning is the result of heat. Either the connection wasn't fully tightened to specs which caused extra resistance and heat (possible and more likely). Or the contacts in the relay started to fail due to extra resistance and heat (possible but less likely).
  8. Bigbob22
    Bigbob22 New Member
    replaced relay and just drove it 10 hours up to the mountains and back and she drove well no burning smell!
    Tbkilb01 and bisco like this.
  9. Tony Hong Nguyen
    Tony Hong Nguyen New Member
    Guam u.s.a
    you have to torque all the 8mm nuts on each cell. For code P0AA6 remove the negative strip that on the HV battery. The P0AA6 will go away. Reset the both battery HV and 12v. You will be okay. I just finish with my.
  10. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    This is BAD advice. Removing the ECU's ability to detect a P0AA6 does not fix it. Ignorance is not bliss in this case.
    Sean2005Gen2CA likes this.
