Help With HV Traction Battery - Voltage(s)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by chris14020, Mar 21, 2018.
  1. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Sorry, not lead. Load.
    His car does not start, so he can't measure voltage during driving
    Prodigyplace likes this.
  2. fatfash
    fatfash Junior Member
    US
    Bought the car accident with impact on the passenger doors both front and rear. As at the time car was delivered it runs and drive with 105k miles
    52,863
    thanks. to get it straight:
    1) you bought a car after it had been in an accident, not salvage title, and it started and drove how many miles before you took it to the body shoppe?
    2) what happens when you plug it in?
    3) who diagnosed your low cells, and how did they do it?
  4. fatfash
    US
    1) The car is salvage but runs and drive, the damage was just the door.
    2) The charging light icon on the charging point on the car comes on for like 5 seconds and off when the charging timer is set but nothing happens on the dash
    3) Myself with Launch EZdiag
  5. bisco
    52,863
    how many miles did it drive after you bought it?
    how many times did you charge it?
    not sure your reader will work correctly on it.
  6. bisco
    52,863
    fwiw, we haven't seen many/any bad hybrid batteries, and some members are closing in on 200k.
  7. fatfash
    US
    The car was delivered to the body shop but only moved it couple of feet. We didn't charge it thinking the job would not involve the HV battery. can you recommend one for me and where to get it
  8. fatfash
    US
    I also don't want to believe the battery will just die like that
  9. bisco
    52,863
    tech stream, amazon. there are a bunch, so you'd have to look through the threads here to find one that suits you. you also need a certain spec laptop.
  10. bisco
    52,863
    did you check to make sure someone didn't disconnect the orange safety plug?
    and i still think you should check the 12v, sometimes new are low in charge, or defective.
  11. fatfash
    US
    okay.
  12. fatfash
    US
    okay.
  13. fatfash
    US
    checked the 12V, it seems okay at 11.89V. Saw somewhere it could be that the DC/DC converter fuse (120A fusible link) is blown, though am yet to find a way to test this
  14. bisco
    52,863
    11.9v is basically dead.
    jerrymildred likes this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Not good at all if that was with no load after sitting overnight. But I don't think that would prevent the EVSE from charging the hybrid battery.
  16. fatfash
    US
    okay. I have been on the car trying to fix it with the battery connected, which from opening and closing of doors will amount to a drop in voltage.
  17. bisco
    52,863
    if you're committed to the battery without more testing, there's no more to say.
  18. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    I think he already changed the 12v battery, right?
  19. Prodigyplace
    12,717
    11,849
    Central Virginia
    Post 34 seems to indicate that.
  20. bisco
    52,863
    correct, see my post #50.
