Help With HV Traction Battery - Voltage(s)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by chris14020, Mar 21, 2018.
  1. fatfash
    fatfash Junior Member
    US
    Those were intact. Thinking of checking the battery fusible link
  2. j12piprius
    j12piprius Junior Member
    35
    Central California Coast
    The charging indicator did the same thing when I first tried charging a week ago. I needed to push down the foot brake, and after pushing the charging connector all the way in, to pull it back firm in the socket. After doing both of these, the indicator stayed on and the battery charged.
  3. chris14020
    chris14020 Junior Member
    29
    26
    Buffalo
    I'm back to tie up loose ends, and help anyone else that may run across this issue. I did manage to manually charge the battery cells (don't do what it did because it's dangerous, but I used a 12v 2A charger and linked batteries into 'cell packs' of 3, one at a time, and brought them up under supervision like that -- yes, all of them). So, they were all reading pretty damn close to what they should, and I got them within .2v of each other as well!
    However, the car still refused to start. It still said "Check hybrid system" and wouldn't go Ready. I had a plethora of codes, that I was fairly sure was the issue. Codes for the HV circuit relay being intermittent, codes for the plug-in portion not functioning at all, all sorts of (seemingly) random codes. However, after many many many frustrating hours of trying, I found a very curious thing in AllData, advising about a feature that sounded a lot like "ignore the fact that the battery pack is low, and try to start anyways" (I forget the exact option). It is in Techstream (I used 12.10.019) under Hybrid System/HV System, then 'Utility'. It will basically ignore that the voltages are low, and allow you to start the vehicle to Ready / On. It eliminated that "Check hybrid system" message on the dash, for me, and allowed me to start it (but not without warning that if you turn this safety off, and don't have your issues fixed, you might set yourself or your car on fire -- so be careful!) When this is done, you can give the vehicle gas while in P and charge the HV battery, to what it wants to see.
    And that, is how I tore my hair out for hours and hours, over a damaged ECU (I replaced it with a used one), and a battery that was too low for the Prius to want to start. Surprisingly, I never came across that tip anywhere, to try it. I hope this helps someone in the future. Thank you all again for all your help and suggestions!
  4. chris14020
    29
    26
    Buffalo
    Just came back to update for anyone else who may run across this thread in the future. The exact name is "HV Batt Cell Low Volt READY ON Prevention Cancel", under Hybrid System/HV System > Utility. Here is a PDF of some info related to this that I snagged from AllData, since I know many of you might not have access to it. I hope it helps someone!
    QuantumFireball and Yea Right like this.
  5. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Wao! I have never came across such a methodology from tech stream, or so. I'm already jotting that info down on my shop notebook.
    Thanks so much!
  6. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Does this means you performed that strategy, after you tried to clear the codes, and it didn't work?
    This is an interesting discovery.
  7. chris14020
    29
    26
    Buffalo
    Yes sir, I tried clearing the codes, everything -- and even after I swapped the main ECU (in the engine bay next to the fuse box) it still had the "check hybrid system" message. The only thing that allowed me to start the vehicle with that message was using the methodology I mentioned (the ready on prevention cancel option), after running that it started just fine.
    On a separate note, I also realized that the 'low voltage cell stack' codes are permanent codes -- even after recharging the vehicle by running it and clearing things with Techstream it did not seem to get rid of them. Take note of whether they are X'd as "Permanent" or "Permanent" AND "Current". The only way to get rid of "Permanent" but not "Current" codes is to prove to the vehicle that the condition is fixed (and sadly most of the conditions, even in AllData, are listed as "Toyota Intellectual Property"). Even reflashing the ECU doesn't seem to get rid of it.
    j12piprius likes this.
  8. bisco
    52,807
    so you're good?
  9. chris14020
    29
    26
    Buffalo
    Yep, everything's good to go here. I just came back to update this post for anyone else that might stumble across it when trying to fix their problem.
  10. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Are you saying the "permanent" codes are still present? Or did they clear after doing the "HV Batt Cell Low Volt READY ON Prevention Cancel", or after running the "battery diagnosis" or something else? Is the car back to normal now?
  11. fatfash
    US
    from what he explained above, everything is okay and I just followed his post, drove the car for about 20mins and was able to clear both the permanent and current codes after the test drive. Everything seems to be okay for now.
    rahhal.ayyat likes this.
  12. rahhal.ayyat
    rahhal.ayyat Junior Member
    JO
    Thanks a lot my car give the same codes and I fix it whith your advice.
  13. rahhal.ayyat
    JO
    Hello Have you done any battery repair or any procedure before scanning errors and was there a specific reason for the appearance of these errors
