Help with installing XTRONS dvd head unit
Discussion in 'Gen 3 Prius Audio and Electronics' started by MSF1344, Nov 14, 2019.
  1. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    Just bought a aftermarket head unit called XTRONS . but I really dont know about wiring . there is not any wiring diagram in instruction manual and I dont want to take to shop . I remove my original toyota head unit and there are 5 connectors but the xtrons just have 4 . any idea ?
  2. prius2010II
    prius2010II Member
    273
    25
    us
    Xtrons sells a "plug n play" Prius unit but it's only sold as a RHD model. Posters from the US won't be able to help you. You need to contact the seller. Make sure they sent you the correct wiring harness. You might take a picture of the back of your factory radio and send it to the seller. Give the seller complete information, does your original unit come with JBL or factory navigation.
    It's possible they sent you the wrong cable or wrong unit. It's also possible you didn't order the Prius plug n play model.
    How many of the connectors had a cable attached. My factory JBL unit has a socket which isn't used.
    Edit: I checked, on my car the (small) unused by aftermarket units socket is for the factory bluetooth microphone cable. For a variety of reasons plug n play aftermarket units don't use the stock bluetooth microphone. You either install an external microphone or use a built in microphone on the unit.
    You might try the unit.
    #2 prius2010II, Nov 15, 2019
    bisco and SFO like this.
  3. MSF1344
    61
    UK
    Active
    Thank you @prius2010II , My car is imported from japan to UK and it is RHD and my genuine head unit is not jbl , I contacted the seller and send them some photos but they dont know what is that extra harness .
  4. prius2010II
    prius2010II Member
    273
    25
    us
    If it's the smallest plug/socket and your car has bluetooth I'd go with it being the plug for your bluetooth mic.
