Help with Low RPM Metallic Rattle (Video)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ethan Waldman, Jun 26, 2020.
  1. Ethan Waldman
    Ethan Waldman Junior Member
    45
    Vermont
    My Prius has had this low rattle for a long time, but it used to be intermittent. Now it's pretty much all of the time at certain RPMs. It happens when only when driving, not just revving the engine, and only when the ICE is on. It happens at lower RPMs, like if I'm driving about 40mph and have my foot lightly on the gas just to keep the car moving at that speed. The rattle stops when the RPMs get higher. I can hold the throttle right at the point that it makes the rattle and it will keep going and going. Or, if I cross that band of RPM, it rattles and then when the RPMs get higher it stops. It's not something I can feel, just hear. It comes from the engine compartment, maybe a little off-center towards the passenger side.
    Here's a video where I kind of "play" with the rattle. You'll see that I rev through it a few times, and then try holding the RPMs steady around 0:14 and again at 0:20-0:22. Note that the rattle happens both as the engine revs up through it and then again as it goes back down.
    It's annoying, but I can live with it. My reason for posting the thread is that I wanted to make sure it's not the sound of something failing and if anyone else has ever heard anything like this. Turn up your volume so you can hear it over the road noise!
    Kasra likes this.
  2. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    I'm glad you've said something. I believe I have the same sound (which is obvious in the car, but hard to record) and it too started intermittently and has progressively become constant at low RPMS. I've contemplated mounting a camera in the engine compartment when driving to try and capture the noise better. However, my rattle seems to be coming more from the drivers side and usually only makes the noise while the inverter engine appears to be part of acceleration. When the window is rolled down and I'm near a building, i can definitely hear it louder. My initial thought was vibration at that engine speed was causing the exhaust shields to rattle, but there doesn't seem to be any broken or loose attachment points anywhere. Another thought was the brake dust shield, but flicking/vibrating that doesn't seem to produce a similar metallic sound. I was just waiting to post something until i had a better recording.
    PrimeDan and Kasra like this.
  3. Mendel Leisk
    42,377
    I hear similar, off-and-on. It occurs in a narrow zone of the acceleration spectrum: a little more or less pressure on the gas pedal and it goes away. I seem to recall someone narrowed it down to a bracket for a small diameter coolant hose, at the front/right corner of the engine bay. The hose breaks at a joint, one side has a hose clamp, the other does not. Anyway, they thought it was that bracket rattling.
    Found a pic:
    PrimeDan and spiralhelix like this.
  4. Ethan Waldman
    45
    Vermont
    I found that bracket and gave it a shake. Felt very solid, so I don't think that's it. But glad other people are hearing it!
  5. spiralhelix
    255
    220
    Illinois
    Yeah, me too. Since mine is a Lexus ct, that bracket is slightly different on mine. I too tried to move it and was pretty solid as well.
    I will break down and try and get a microphone mounted under the hood over the weekend and see if I can’t get a better recording and/or location
    iPhone ?
  6. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Loose heat shield perhaps?
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Mine wiggles but doesn't make any noise.
    Disclaimer- this reply may not apply in all situations.
  8. ttou68
    ttou68 Active Member
    351
    211
    I would check the heat shields and exhaust bracket...
    I've had both loose on a 2010 with 280K miles...
  9. Dr Strangelove
    Dr Strangelove New Member
    Nj
    Sounds to me like the center exhaust bracket is cracked. I had the same sound. It's under the middle of the car and the bracket breaks off the exhaust pipe that it is welded to. I'd check there first.
    spiralhelix likes this.
  10. Ethan Waldman
    45
    Vermont
    Do I need to remove a panel for that or should it be visible under the car?
  11. Aaron F
    Aaron F Junior Member
    Kansas
    Had a similar sound in my 2010 w/ 75k miles.
    It was a piece of the exhaust shielding. I used a rivet gun to put the shield back in place and the rattle went away.
    I highly suggest putting the car on ramps and with it in park slowly press on the gas & extremely slowly back off the gas to find the exact RPMs you get the sound for. If you can then have someone in the car press on the gas with you under the car finding the rattle doesn't take but a couple seconds.
    I can definitely relate to how frustrating this is. Good news is most of the time if the rattle isn't the entire exhaust system falling off (not likely) it isn't a big deal.
    Kasra and kenoarto like this.
  12. milksheikh
    milksheikh Future Prius Owner (hopefully)
    Brooklyn, NY
    I have the mid-exhaust bracket weld problem. What's the best solution?
    It's visible under the car. You don't need to lift the car even, just look underneath and reach with a 2- or 3-foot piece of wood -- hold it against the bracket while someone is revving to reproduce the rattle to see if that dampens it. Looks like this:
    Papawrench and Mendel Leisk like this.
  13. Mendel Leisk
    42,377
    Hands down the funkiest wheel chocks lol.
    PrimeDan likes this.
  14. BrendonG
    BrendonG Junior Member
    Brisbane, Australia
    i-Tech
    Hi Ethan/all. Were you ever able to solve this noise? I'm getting the exact same problem and it doesn't seem to be either the coolant hose nor the exhaust system.
    Managed to mount a phone under the car and get a recording
  15. BrendonG
    Brisbane, Australia
    i-Tech
    Update for those that find this thread in the future. It was a loose/rusted mesh spacer on the heat shield for the exhaust/cat. The bolt was still very tight, but the steel mesh that's meant to hold the heat shield firm was all deteriorated, allowing the heat shield to rattle at a certain RPM.
    There's no way to replace the spacer from what I can tell, we had to snip the shield to remove it.
    Pics here
    Kasra and Papawrench like this.
  16. Papawrench
    Papawrench Junior Member
    Ottawa, ON
    2013 Prius v wagon
    I've had this rattle too and thought I finally found the source after your tip to check this bracket. It was separated completely but even after removing it a rattle is still there. I guess I'll have to get under it and check the heat shields more thoroughly.
  17. Kasra
    Kasra Member
    49
    27
    Irvine, CA
    Thanks for detailed pictures. I will check this on my next oil change and post here. Mine is 2015 with 170K miles, the noise was noticed around 160K miles
