help with maintenance
Discussion in 'Gen 2 Prius Fuel Economy' started by misterdean, Aug 19, 2018.
  1. misterdean
    misterdean Member
    206
    29
    FL
    i gotta do something besides worry about it. i followed a guide i found on here to get those battery readings from the center console. figured that was the proper thing to do but mendal said those measurements are meaningless use a volt meter. you are now the second person to recommend the volt meter. it's either buy the volt meter buy a battery or do nothing. it's not like i have any other suggestions at the moment besides charge the battery. to be honest i am considering that but wasn't sure if it was detrimental to charge a battery that tested good.
    #21 misterdean, Sep 6, 2018
    52,858
    not with a proper charger.
    52,858
    mendel has other suggestions in post #2
    52,858
    now that you've clarified the 10 mpg drop, you'll probably get different advice.
    are you aware of the gas tank bladder issue?
  5. misterdean
    misterdean Member
    206
    29
    FL
    what is a proper charger? i was thinking about charging it at home with a trickle charger.
    i am not aware of a bladder issue. pretty much everything i have read suggests tires and 12v.
    #25 misterdean, Sep 6, 2018
  6. bisco
    52,858
    trickle should be fine.
    gen 2 prius has a rubber bladder that expands and contracts on a whim. single tank results can be misleading, and only long term tank averages are close to accurate.
  7. misterdean
    misterdean Member
    206
    29
    FL
    EDIT - this isn't about fuel economy any more so i will post in troubleshooting.
    #27 misterdean, Sep 15, 2018
