Help with multimeter settings to manually bleed coolant
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Collie, Jan 9, 2026.
  1. Collie
    Collie Junior Member
    23
    Thanks for the reply Chapman.
    As has also been mentioned a couple times, respectfully, this is pump number 3. Using the unfused jumper resulted in large sparks and dead pumps. As also mentioned I’m attempting to try something new because insanity is doing the same thing over and over expecting a different result.
    This time, as I mentioned, I spoke to a toyota tech who said try it this way with a multimeter - I searched for and posted a video of others making it work. The other option he suggested was to use a FUSED jumper to avoid any shorting. Because I live in the mountains with no access to get into town to purchase said jumper with fuse, I’m doing my best to work with what I have.
    Thank you for all your help.
  2. Collie
    23
    If I have to take that wheel off one more time… lol
    Sorry if I came off brash guys, I just stripped the #6 trying to open the bleeder valve and don’t have another one. FML.
    PriusCamper likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,389
    5,409
    Pacific Northwest, USA
    I always tell people that the main difference between a professional and a DIY is how long it takes to get a part or tool. A pro will always have everything a few steps away when they get started and a DIY person will have to run an errand or order online mid project.
    Collie likes this.
  4. ChapmanF
    18,947
    I wasn't there at the time and, therefore, can't say what did cause your dead pumps.
    I don't have to have been there to be able to say what didn't cause it; we can rule out any explanation that would require changing how electricity or multimeters work. Whatever does explain your experiences, it won't be that.
    If you run into further issues and post in enough detail, it may be possible to pin down what you're seeing.
    Getting a wire into the wrong terminals of a socket—different ones than used with the meter—would be one way to see different results. But again, I wasn't there watching you.
    Collie likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,979
    6,885
    Texas Hill Country
    1. Running it for 15 seconds and wait 1 minute would be fine.
    2. Keep coolant in the funnel. If it drains into the system without the pump running that is ok.
    3. According to the video, the meter allows you to judge the pump speed.
    4. You could write down the steps he used and follow the steps at your own pace.
    5. Sparks are ok.
    #25 rjparker, Jan 9, 2026
    Collie likes this.
  6. Collie
    23
    That’s pretty accurate! In this case I had (2) of them things and stripped them both.
    Maybe it’s time to finally give GripEdge brand a shot
    Thank you everyone again and thanks as well to RJ for simplifying it for me
  7. Collie
    23
    Does anyone have any ideas on getting the stripped bleeder fastener off? It’s the one that comes out with the #6 T handle. Stripped 2 trying to get it out.
    Is it going to come to trying to find a narrow enough screw extractor, pinching off the coolant lines and ordering a replacement part online after extracting it?
  8. pasadena_commut
    pasadena_commut Senior Member
    2,997
    930
    Southern California
    There is a drain valve under the CHS, but it is the lowest point in the whole ICE coolant web, so useless for removing air. It works great for draining all the ICE coolant though, and I and at least one other person have refilled the loop back up through that valve.
    Refill engine coolant, without trapped air. (unique method) Gen 2 | PriusChat
    Oddly, with very different results. Albert found very little air after doing this, whereas it appears the CHS was pretty much completely full of air when I did it. All that air came out by running the CHS pump, there were just a few small bubbles elsewhere.
  9. pasadena_commut
    2,997
    930
    Southern California
    Regarding the radiator bleeder, see this thread:
    Radiator bleeder valve stripped, what should I do? | PriusChat
    I seem to recall Aiman's video stating that there was some issue about when to fully tighten that bleeder, and doing it wrong resulted in it being so tight when cold that it could not be opened. I think I recall that he said it should be only loosely closed when hot, and then tightened a bit more when it is cold. Watch the video to be sure as my memory isn't improving with age.
    One advantage of bottom filling the ICE system is that, so far (2/2 examples) it wasn't necessary to open that bleeder at all.
