Help with P3191 and battery recommendation?
Discussion in 'Generation 1 Prius Discussion' started by War_Destroyer, Mar 21, 2025.
  1. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    There is no way this charcoal canister will fill with oil unless it is disassembled and oil is poured into it.
    Charcoal canisters are designed to store fuel vapors and direct them into the air ducts while the engine is running.
  2. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
  3. War_Destroyer
    War_Destroyer Junior Member
    42
    Los Angeles
    2002 Prius
    I spoke too soon, this morning the car would not start on its own unless I took off immediately while the hybrid engine was turning the gas engine.
    My family is just too spoiled by the other cars we have. They're all from the same period like our '96 Lexus LS400, '04 LS430, '03 RX300, I personally daily a '00 Mercedes-Benz E430, but it is hard to give up on the quiet comfort they provide, they don't have the craziest V8's, but nobody will harass or bully you on the road. My biology professor had a 2001 Prius himself, and they stole his catalytic converters right on campus lol I worry about the cats too, I always park it in the garage or as close to the house on the driveway, but I never take the Prius if it is going to be parked in a public area for long. With school being hectic right now, I've found it easier to just drive something else, than make time to sort this P3191 issue, but I also rather keep it then sell it to someone that isn't a fan of these 1st gen Prius.
  4. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    P3191 failure to start an internal combustion engine may be due to problems with the fuel supply, poor ignition (spark plugs, coils), incorrectly adjusted fuel-air mixture, leakage problems in the air supply system. This is checked consistently and carefully. If the high-voltage battery is normally charged, there are no errors on it, then it rotates the MG, which, like a starter, rotates the engine. What happens in a regular car when the starter rotates, but the spark plug does not work? The engine is troit and does not start. The same thing happens to you.
  5. War_Destroyer
    42
    Los Angeles
    2002 Prius
    So I got back at it, the car sat for a little bit this week, so I decided to test it, and start it using my jump starter. Voltage read 12.1v on the jumper wires before connecting the jump starter. To my surprise the car started fine with the addition of the jump starter. Maybe it would have started fine on its own, but I'll save that for tomorrow.
    Anyway, I decided to clean the throttle body using the CRC throttle body spray, a microfiber towel, blue shop towels, and a tooth brush. I ruined a perfectly good microfiber towel, the tooth brush was very effective in breaking the gunk down, and the blue shop towels for cleaning things up, and wicking up the cleaning fluid and that pool of oil? That pool of oil is normal right? Honestly I did not feel any griminess or stickiness from the throttle body outside of the spring and gear tension.
    We'll see how she acts tomorrow morning!
  6. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    You made the right choice to clean the throttle valve, it really does look dirty in the photo.
    Dirt on the throttle valve can interfere with its movement in different modes and disrupt the required volume of air supply for the formation of the fuel mixture.
    To reduce the volume of oil in the throttle valve, you can install an oil catcher on the hose from the PCV valve.
    War_Destroyer likes this.
  7. Trombone
    389
    130
    2002 Prius
    That looks great! Nicely done!
    BTW, there is a helpful video on the topic of throttle body cleaning, here:
    ammdb and War_Destroyer like this.
  8. War_Destroyer
    42
    Los Angeles
    2002 Prius
    Started up fine this morning, we're getting somewhere, maybe it did only need a little maintenance and attention. Being a hybrid and the kind of indirect nature of the code, really had me more spooked than necessary lol
  9. ronlewis
    ronlewis Active Member
    1,061
    206
    texas
    2001 Prius
    Although the cat-stealing craze seems to have slowed down, I'd still worry in LA. What I'd do if I lived there is replace my OEM pipe - manifold to the flange under the rear seat, driver's side with an aftermarket assembly. I did have a couple extra sitting around but threw them out on my last recycler run. I do have some on the cars that I'll switch one day. Anyway...
    Just build the same set-up they do in all the others non-CARB states when the cat gets stolen. Thieves cut it between Cat2 and the resonator and the aftermarkets come with the manifold flange. Just need a short pipe to the resonator. And you need the VAV reservoir hack, whether you get an OEM canister (I got a couple somewhere in the garage) or some other canister.
    Only the stupidest of the stupid thieves won't recognize that you're running a worthless aftermarket cat and not steal it. But if you run into the stupidest guy, it's still a cheap aftermarket cat. They're well under $100 on Ebay and easy to weld on. And the entire assembly just has 4 bolts and two rubber bands holding it on.
    Now, you run that system year round, except when you need to get smog tested. Swap your OEM, pass the test, and take it back off.
    Added random bonus, when you get ready to sell the car, keep your OEM cat and sell it yourself. They're like a stash of gold - just watch the commodities markets and sell at a high point.
  10. War_Destroyer
    42
    Los Angeles
    2002 Prius
    The Prius has been working fine since I cleaned the throttle body lol I cleared the ECU and once the Torque app showed that all the emissions readiness checks were green, I took the car to get smog checked and it passed, I was worried that P3191 would come back perhaps fail the test, not sure if it does, but it hasn't, and the Prius even seems more responsive.
    Yeah, it got pretty bad for a long while there, all the gen 1 Prius that I used to routinely see are all gone now. I have not seen one in a very long time. Every once in a while they show up at my local salvage yards. Are there any worthwhile easy to reach valuable parts that I could salvage from them?
  11. ronlewis
    1,061
    206
    texas
    2001 Prius
    There have been dozens in the CA auctions over the last couple of years. Pretty consistent supply. Some real nice ones. The CA insurers look for any reason to total them out. I bought a nice one it LA - the one I just posted about - and one in Seattle. But since I quit driving the country, it costs too much have them shipped back to Tx and there's no market for the cars or parts here. If anyone wants to mess with G1s California is the place to be.
    I finally quit buying last year. I have 14 left, 6 running, 2 for parts, and others to be repaired. But I'm too old, and pretty feeble-minded these days, to finish them off. If I could work on cars more, I'd prioritize getting my ambulance and F450 up to speed, just because I need them going forward and have enough Prii to drive the rest of my life, lol.
    I bought almost all of these at scrap value in auctions - scrap being around $1000 between the cat and scrap metal value - so I could just throw all the unfinished ones away and not lose money. Instead, I spend $400/mo on storage yards to let them sit, lol. (that feeble-minded thing, lol). But, I gotta pull the trigger, so I'm back at it. Will be hauling the parts cars away asap. Sold one of good ones this week.
    The price of cats went way up during the pandemic, but came back down. I've not sold one of mine in a year or so. IIRC, I got around $650. I'll just hang on to the rest for a while to see if the metal prices follow gold upwards, but haven't so far.
    That's about it. There could be some folks, like I was, buying and combining wrecked ones into good cars, but there's plenty of parts at the dismantlers, so not much market for parts - unless it's in CA. I run my Marketplace listing in LA, SF, and some others cities, but the shipping costs are too much, and I don't wanna mess with removing/packaging. You would have more opportunities for local pickup.
  12. ronlewis
    1,061
    206
    texas
    2001 Prius
    I have a tiny hope that the market picks up in the next year. It'll be the 25th anniversary of the Prius and I expect Toyota to include these cars in their marketing. I suggested as much to their CMO in an email. I suggested, not sure if here but on some FB Prii pages, that an road rally be organized to celebrate. I think it's amazing that Toyota hybrid technology has basically had two lifetimes - that's crazy rare in technology. Our cars started it by beating up gas-only tech, and now they came back to fight off the EV competition.
    I'd love to see a marketing campaign in which Prii of all generations do what they do better than EVs - take long road trips. Have regional drive-in rallies/parties where we all meet and form caravans, then drive to a national rally located somewhere EVs have a hard time going, out in the middle of nowhere, kinda like a Sturgis for Prii with multiple trail rides coming from 5-6 directions to converge for the fun. Our Gen1s could lead the way. We'd be cool again. I sent that idea to the CMO, but no response, lol.
    2001s started shipping at the end of this year 25 years ago.
    MAX2 and War_Destroyer like this.
  13. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Unfortunately, there are no eternal cars.
    The first Prius (NHW10) came out in 1997 in Japan and now there are maybe a few dozen of them still plying the roads.
