Help with Parts
Discussion in 'Prius v Technical Discussion' started by mb71048, Sep 3, 2024.
  1. mb71048
    mb71048 New Member
    NC
    2015 Prius v wagon
    Hi Everyone,
    I’m coming from a 2012 Gen 3 to a 2015 Prius v. I had the issues with satellite radio and successfully installed a new receiver (on the second attempt part doh). Happy to say I have satellite radio working.
    Sadly, the antenna mast threads do not fit, it is too big for the receiver. All parts were ordered from Toyota directly and the mast is original. Not sure what to do other than tape it up for now. Going to try to call the dealer that sold me the parts tomorrow. Anyone aware if there could be a Toyota mast with a smaller diameter? Does anyone know what the specs are for the screw?
    My other casualty was the tie down d-ring bolt over the battery. Snapped in two putting it back in, trying to drill it out but I’m going to take to my local mechanic before I really mess it up. does anyone know the specs or part number to the tie down bolts?
    Many thanks in advance!
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,025
    6,916
    Texas Hill Country
    Are you saying you changed the preamp on the roof but now the mast does not fit?
    If so, it’s possible they sent the wrong preamp. There are three. These were my choices when the preamp went out.
    Air_Boss likes this.
  3. Mendel Leisk
    42,288
    There’s more than one of these? Remove another, take it to a hardware store, try threading it onto their metric nuts, then when you find a compatible nut use it to determine compatible bolt.
    Or dealership parts department, they’ll be able to get the cosmetically identical one.
    so you were using your Milwaukee Impact to speed up the job? ;)
  4. mb71048
    mb71048 New Member
    NC
    2015 Prius v wagon
    I just asked this on another thread, sorry I missed this reply. It seems to be a softer metal not for many re-uses. Did use a drill with a 10mm socket, torqued out very easily. Snapped while using a socket wrench. Thanks for your reply!
    For reference, the mayday (most expensive) assembly the antenna screw is 6mm. Non-mayday (middle part above, 2nd most expense) assembly takes a 5mm antenna. Toyota has part numbers for both, the more expensive option is the 6mm screw.
    #4 mb71048, Sep 6, 2024
  5. mb71048
    mb71048 New Member
    NC
    2015 Prius v wagon
    THANK YOU by the way! I used your guide and it got the satellite radio back. Just wish I didn't over tighten the first assembly cutting the 4 cords. That hurt...
  6. Mendel Leisk
    42,288
    Cut back on the spinach? ;)
    Air_Boss and mb71048 like this.
  7. Air_Boss
    Air_Boss Senior Member
    4,247
    1,195
    New Yawk
    Three foot cheater bar?
